Which Transmission? (4R100 or 4RW70)
swapping trans
Now we have established which trans the early Expos came with can we use the 4.6 trans in a 5.4 truck? I have a 2000 4.6 Expo but the engine gave out 20k miles after i had trans rebuilt. I bought a 99 with a 5.4 but the trans slips a bit. Rather tgan rebuild this trans can I just put my rebuilt trans in it?
I think we've come to the following conclusions on transmission oil. I hope this helps future searchers:
1. All Expeditions prior to 2003, that have the 4.6L V-8, use the 4R70W transmission. No matter what fill it came with, you can and should use Mercon V in it.
2. All Expeditions prior to 2003, that have the 5.4L v-8, use the 4R100 transmission. In all cases, you should use Mercon and NOT MERCON V in it.
This information is based on comprehensive research and some healthy reference to Mark Kowalsky, the resident transmission guru.
Now--have we figured out the 2003+ trannies? Do they all have 4R70W trannies using Mercon V?
Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
99' Ford Expedition transmission issue
OK I'm having an issue with my 99' Ford Expedition transmission, I believe it's a 4RW70 transmission and it shifts from 1st to 2nd just fine when it goes to 3rd it shifts to neutral no lock up for say. Any ideas? I traced the wireing and connections look to be OK no torn or worn wires, also hooked up to a computer and no transmission codes came up. any help you'll be appreciated thanks
1'stonraceday
10-18-2017 08:22 PM
Daddy23Hubby21
1997 - 2003 F150
09-07-2017 04:04 PM
Sevrock
09-24-2016 10:04 AM
1999, 4r100, 4r70, 4r70w, difference, expedition, fe, fit, ford, mercon, specs, towing, trailer, trans, transmission
