98 Ranger, 5R55E with Blinking O/D light - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-10-2004, 03:54 PM
iverger's Avatar
iverger iverger is offline
iverger is starting off with a positive reputation.
98 Ranger 4.0L 5R55E auto 4x4
1) I replaced my 98 4.0 with one from a 99 Explorer.
2) The O/D light started blinking and the converter won't lock up.
3) Had the tranny rebuilt at a local shop, problem still exists.
4) Tourque converter blew up and contaminated tranny.
5) Replaced the complete tranny from converter to tail shaft, including TCC and valve body.
6) Spent 3hrs at the Ford dealer last night to no avail.
We are all stumped, tranny shop, Ford dealer and myself.
What am I missing?
Has to be something on the engine. Since the tranny is electronic what sensors does the ECU take into account when deciding when to send a signal to the TCC solenoid to lock/unlock the converter?
It locks it for a mile or 2 and then seems to get confused, quits and starts flashing the O/D light.
Old 03-10-2004, 08:40 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Re: 98 Ranger, 5R55E with Blinking O/D light
Quote:
...Has to be something on the engine. Since the tranny is electronic what sensors does the ECU take into account when deciding when to send a signal to the TCC solenoid to lock/unlock the converter?
Easier question to answer would be what sensors AREN'T used?
Quote:
Transmission Electronic Control System
The powertrain control module (PCM) (12A650) and its input/output network control the following transmission operations:
- Shift timing.
- Line pressure (shift feel).
- Torque converter clutch.
The transmission control is separate from the engine control strategy in the PCM, although some of the input signals are shared. When determining the best operating strategy for transmission operation, the PCM uses input information from certain engine-related and driver-demand related sensors and switches.
In addition, the PCM receives input signals from certain transmission-related sensors and switches. The PCM also uses these signals when determining transmission operating strategy.
Using all of these inputs signals, the PCM can determine when the time and conditions are right for a shift, or when to apply or release the torque converter clutch. It will also determine the best line pressure needed to optimize shift feel. To accomplish this the PCM uses six output solenoids to control transmission operation.
The following provides a brief description of each of the sensors and actuators used to control transmission operation:
Intake Air Temperature (IAT) Sensor
The intake air temperature (IAT) sensor provides the sequential fuel injection (SFI) system mixture temperature information. The IAT sensor is used both as a density corrector for air flow calculation and to proportion cold enrichment fuel flow. The IAT sensor is installed in the air cleaner outlet tube. The IAT sensor is also used in determining electronic pressure control (EPC) pressures.
Throttle Position (TP) Sensor
The throttle position (TP) sensor is a potentiometer mounted on the throttle body. The TP sensor detects the position of the throttle plate and sends this information to the powertrain control module. The TP sensor is used for shift scheduling, electronic pressure control and torque converter clutch (TCC) control.
Engine Coolant Temperature (ECT) Sensor
The engine coolant temperature (ECT) sensor detects temperature of engine coolant and supplies the information to the powertrain control module (PCM). The ECT sensor is used to control torque converter clutch (TCC) operation.
Anti-Lock Brake Speed Sensor
The programmable speedometer/odometer module (PSOM) receives input from the rear brake anti-lock sensor. After processing the signal, the PSOM relays it to the powertrain control module and the speed control module. Information from the PSOM is used to help determine shift scheduling, torque converter clutch operation and electronic pressure control (EPC).
Mass Air Flow (MAF) Sensor
The mass air flow sensor measures the mass of air flowing into the engine. The MAF sensor output signal is used by the powertrain control module (PCM) to calculate injector pulse width. For transmission strategies the MAF sensor is used to regulate electronic pressure control, shift and torque converter clutch scheduling.
Air Conditioning (A/C) Clutch
An electromagnetic clutch is energized when the clutch cycling pressure switch closes. The switch is located on the suction accumulator/drier. The closing of the switch completes the circuit to the clutch and draws it into engagement with the compressor driveshaft. When the A/C is engaged, electronic pressure control (EPC) pressure is adjusted to compensate for additional load on the engine.
Electronic Ignition (EI) System
The electronic ignition consists of a crankshaft position sensor, two four tower ignition coils and the powertrain control module. The ignition control module operates by sending crankshaft position information from the crankshaft position sensor to the ignition control module. The ignition control module generates a profile ignition pickup (PIP) signal (engine rpm) and sends it to the PCM. The PCM uses PIP signal in the transmission strategy, wide-open throttle (WOT) shift control, torque converter clutch control and EPC pressure.
Brake Pedal Position (BPP) Switch
The brake pedal position (BPP) switch tells the powertrain control module when the brakes are applied. The torque converter clutch disengages when the brakes are applied. The BPP switch closes when the brakes are applied and opens when they are released.
Transmission Control Switch (TCS) and Transmission Control Indicator Lamp (TCIL)
The transmission control switch (TCS) is a momentary contact switch that allows the driver to cancel operation of 5th (overdrive) gear. The TCS is located on the end of the selector lever. When the driver initially presses the TCS a signal is sent to the powertrain control module. The PCM uses the shift solenoids to disengage/disable 5th gear operation and activate the coast clutch. At the same time the PCM illuminates the transmission control indicator lamp (TCIL), to notify the driver that 5th gear is canceled. When the TCS is pressed again, 5th gear operation is enabled, the coast clutch is released and the TCIL is turned off.
Whenever the ignition is cycled (vehicle shut off then started again) the TCS is turned off and 5th gear will be enabled, even if the TCS had been on when the ignition was shut off.
Turbine Shaft Speed (TSS) Sensor
The turbine shaft speed (TSS) sensor is a magnetic pickup that sends the powertrain control module torque converter turbine speed information. The PCM uses TSS information to help determine electronic pressure control (EPC) and torque converter clutch (TCC) operation. The TSS sensor is mounted internally on the center support.
4x4 Low (4x4L) Switch
The 4x4 low (4x4L) range switch is located on the transfer case cover. It provides an indication of when the 4x4 transfer case gear system is in the low range. The PCM then modifies the shift schedule for 4x4L transfer case gear ratio.
Output Shaft Speed (OSS) Sensor
The output shaft speed (OSS) sensor is a magnetic pickup, located at the output shaft ring gear, that sends a signal to the powertrain control module to indicate transmission output shaft speed. The OSS is used for torque converter clutch control, speed scheduling and to determine electronic pressure control.
Digital Transmission Range (TR) Sensor
The digital transmission range (TR) sensor is located on the outside of the transmission at the manual lever. The digital TR sensor completes the start circuit in Park and Neutral, the back-up lamp circuit in Reverse and the neutral sense circuit (4x4 only) in Neutral. The digital TR sensor also opens and closes a set of four switches that are monitored by the powertrain control module to determine the position of the manual lever (P, R, N, D, 2, 1).
Transmission Fluid Temperature (TFT) Sensor
- The transmission fluid temperature (TFT) sensor is a thermistor-type sensor that varies a reference voltage signal. The resistance in the TFT varies with temperature. The powertrain control module (PCM) monitors the voltage signal across the TFT, and uses this information to determine the transmission fluid temperature.
- The TFT is located on the main control body wiring harness assembly.
- The PCM uses the TFT signal to help determine shift scheduling, torque converter clutch operation and electronic pressure control (EPC).
It sends a voltage signal to the powertrain control module. The voltage signal varies with transmission fluid temperature. The PCM uses this signal to determine whether a cold start shift schedule is necessary. The shift schedule is compensated when the transmission fluid temperature is cold. The PCM also inhibits torque converter clutch (TCC) operation at low transmission fluid temperatures and corrects electronic pressure control.
Electronic Pressure Control (EPC) Solenoid
The electronic pressure control (EPC) solenoid is a variable force style (VFS) solenoid. The VFS type solenoid is an electro-hydraulic actuator combining a solenoid and a regulating valve.
The powertrain control module varies the current to the EPC solenoid.This action causes the solenoid to regulate transmission line pressure and line modulator pressure. This is done by producing resisting forces to the main regulator and line modulator circuits. These two solenoids control clutch application pressures.
Shift Solenoids A, B, C, and D
Four On/Off shift solenoids allow the powertrain control module to control shift scheduling.
- The solenoids are two-way, normally open style.
- The shift solenoids (SSA, SSB, SSC, and SSD provide gear selection of 1st through 5th gears by controlling the pressures of the shift valves.
- SSD is also used to apply and release the coast clutch.
Torque Converter Clutch (TCC) Solenoid
The torque converter clutch (TCC) solenoid is used to control the apply and release of the TCC.
Old 03-10-2004, 11:33 PM
Rand Rand is offline
Rand is starting off with a positive reputation.
98 ranger would be the ohv 4.0... 99explorer would be the sohc 4.0....
Right?
Rand
Old 03-10-2004, 11:40 PM
hreed hreed is offline
hreed is starting off with a positive reputation.
Rock-are your fingers tired after all that?
Old 03-11-2004, 10:07 AM
iverger's Avatar
Thanks Rockledge this is perfect.
The Ford dealership is certain that it is a valve body issue because 1) the symptoms and 2) there is a TSB and upgrade kit for the valve body on the 98-00 5r55e's and 3) the rebuild shop is not likely to replace the valve body due to cost. ($600)
The tranny shop is convinced it is something electronic because 1) the symptoms where there after the engine replace ment and 2) after the tranny rebuild and 3) again after the tranny replacement.
I'm stuck in the middle. Both are valid arguments.
From reading your post and the fact that I am not generating any CEL codes, I think I can focus on those that came with the replacement engine that are on the list. Primairliy the TP and ECT sensors. The TP should generate a code but for $24 I'll replace it anyway. The ECT is a potential problem. I replaced the water pump and thermostat when I installed the engine but the guage still indicates that it is having a hard time warming up.
If neither of those do the job then I am going with Fords recommendation.
Thanks again,
Bob
5r55e No TC Lock Up Chandler Hall Explorer, Sport Trac, Mountaineer & Aviator 8 01-28-2016 01:59 AM
4R55E Question.. ManicMike Explorer, Sport Trac, Mountaineer & Aviator 8 08-25-2014 08:55 PM
5r55e no drive ? Joe Barth Ranger & B-Series 4 02-08-2011 11:13 PM
torque converter clutch question ssjerrys Clutch, Transmission, Differential, Axle & Transfer Case 1 10-20-2010 11:19 PM
Torque Converter Clutch Solenoid g17_jimmy Explorer, Sport Trac, Mountaineer & Aviator 4 07-09-2002 04:27 PM
Tags
5r55e, converter, explorer, ford, lever, lockup, manual, oss, part, position, problems, sensor, solenoid, ssa, tft, torque, tss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
