Variable Assist Power Steering
Old 03-09-2004, 11:02 PM
Adriand's Avatar
Adriand
Adriand is offline
Has anyone out there used a variable assist power steering setup on their truck?
I'm not sure what setup I have (need to do some research) but I'm not thrilled with over-assisted setup I have.
Thanks for your help in advance.
Old 03-12-2004, 07:46 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Over-assisted? What does that mean? What kind of power steering setup do you have?
Old 03-14-2004, 10:25 PM
Adriand's Avatar
Adriand
Adriand is offline
Variable assist power steering
I am a F100 newbie. However, my background has always been sports cars which either has no power steering or ones that have decreasing assist as speed increases.
What I mean by over-assisted is that whether you are at slow speeds or at freeway speeds, the power steering provides a lot of assist. This provides no steering feedback to the driver.
As to what type of power steering I have, I don't know. Unfortunately, I bought the truck from a guy who had all the work done by different shops. While the work appears to be good quality, he has no idea as to what the source for the parts are.
I will begin working on the truck in May and I will have to do some research into what is actually installed.
Old 03-15-2004, 04:38 AM
GreatNorthWoods
Adrian,
Sounds like it could be as simple as running the wrong power steering pump. If you could identify what kind of steering box you have and what kind of PS pump we might be able to help. For example, I know from other posts on here that a GM power steering pump will over assist a Mopar steering box. Are you in a position to take any pictures of your set up? Is there any way to contact the previous owner and find out where the work was done? I'd like to help, but I have nothing to go on...
Old 03-15-2004, 06:14 AM
mr4speedford's Avatar
mr4speedford
mr4speedford is offline
But year of truck do you have? -4speed
2000expedition4x4
1997-2006 Expedition & Navigator
24
08-13-2010 06:23 PM
Kalve
General Automotive Discussion
04-23-2010 10:36 PM
cabloom300
01-20-2010 06:13 PM
tylstruck
01-12-2008 11:45 PM
scottfreeman
Offroad & 4x4
10-04-2007 10:31 AM
Quick Reply: Variable Assist Power Steering
