1995 f150 heater core hot but blowing cold air - Ford Truck Enthusiasts Forums
Old 03-09-2004, 07:59 PM
wellys wellys is offline
wellys is starting off with a positive reputation.
I have a 1995 ford f150. I stripped the heater core it's not blocked, fluid is flowing through both hoses very hot. When i stripped the box in behind the glovebox the heater core is very hot but the top left hand corner is blowing through cold air cant figure it out open to suggestions. Bit of a pain in the rear scraping ice from the inside of the window these mornings... Somebody help please
Old 03-09-2004, 08:29 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Hello wellys and Welcome to FTE!
So you are saying that all the air through the heater core is hot and that the air through the left defroster vent is cold?
Old 03-11-2004, 05:09 PM
no heat
No I stripped out the glove compartment and took the plastic casing off the heater core. The entire core was very hot. No air was passing through, it's not blocked because I took it out. At the top left hand corner cold air was blowing through. This was the only place any air was comming through and it was cold But the rest of the core was hot ??????????? The truck has an a/c if that has anything to do with it.
Old 03-11-2004, 09:31 PM
I would guess that you have a trapped air pocket there. Fluid is still moving through the core but for some reason you have air trapped there and since this is where the air is blowing through it, it does not heat up.
Old 04-07-2004, 08:36 AM
how do i get the air out
Old 04-07-2004, 05:49 PM
randallc's Avatar
randallc randallc is offline
randallc is starting off with a positive reputation.
Find the highest possible part of your water system, undo the hose and run your truck until water comes out of the hose that you took off and fill the rad while the truck is running.
The same thing can be done by putting your truck on a steep hill or high ramps and run the truck for about 20 mins with a hose in the rad filler.
Randall
Heater won't blow hot. Tulsamulerider Cooling, Heating, Ventilation & A/C 6 01-10-2017 10:28 PM
1993 f150 heater problems superman7928 1987 - 1996 F150 & Larger F-Series Trucks 6 01-30-2015 03:08 PM
ok, so is my heater core bad? reedytlr93 1997 - 2003 F150 15 01-08-2011 02:11 AM
97 f-150: heater blows warm, not hot air. svenska57 1997 - 2003 F150 3 12-30-2010 09:43 PM
help my 1988 ford f150 - no heat flfisher2002 1987 - 1996 F150 & Larger F-Series Trucks 5 10-03-2006 09:35 AM
Tags
1995, 1998, 2002, 95, blowing, cold, core, f150, f250, ford, heat, heater, plenum, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
