Brakes on 57
Brakes on 57
Hey all, I got a 57 with a brake problem. 1st off, when I brake, it always wants to pull HARD to the left. What could be causing this?? Maybe the passenger side front not working?? And second, I seem to loose all my brake fluid within a day of filling up the tank (booster?) While this generally happens all the time, sometimes it will not be gone if I had pulled a wagon or something heavy the day before...odd. But I can't see any signs of leaking anywhere, like from the insides of the wheels and all the lines look ok to me. Any help would be greatly appreciated. Thanks
Joe
Joe
The right side wheel cyl is not working, pull the wheel and drum and inspect. If you were losing fluid thru that cyl, it would also make it pull. Chances are it's a bad cyl that causing the pull.
As for the fluid disappearing, I'd check all the wheels and also your rubber hoses and steel lines. You may have a pin hole somewhere. Look for wet spots on the frame or body. Your M/C could be leaking out the back by the piston rod. If you have a separate booster under the frame, look there. It could be sucking it past a blown diaphram in the booster into the vac system. if that was the case, I'd think you'd see evidence coming out the exhaust as blue smoke.
Barry
Barry
....and certainly check your left wheel cylinder too. If that has a leak (which is possible since you don't always loose fluid), it will coat the brake lining creating extra drag and will pull to the left.
Just spring for 2 new front cylinders or better yet, do all 4 while you're at it. Then you don't have to worry about it.
