I installed Hooker Supercomp center dumps on my 55 with no problems at all. Im not sure if these will work with your setup, but look around, there are ones that will fit.
Originally posted by bobbie-d I am putting a 302 in a 1950 F-1 and looking for a set of headers that will clear the stock steering box on left side
If you are running a stock steering box, the Sanderson F3 header should fit your truck if you want a full length header, otherwise Mustang shorties or most any other SBF block hugger header should work. Speedway Motors probably has a cheaper equivalent of the F3 Sanderson header.
