Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-08-2004, 07:18 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
Garage is empty, add now
FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.
Detecting ping
I have a 2000 Lincoln Navigator with the 5.4l 32V Intech motor. On top, I have a Kenne Bell SC pushing 9 psi. What I’m curious about finding out is a definitive way to determine if I am suffering from ‘ping’.
I’ve had a bevy of high performance vehicles during my life so I’m well aware of what it sounds like and I believe I hear a faint pinging at time when I drive. I only think I’m hearing ping between 0-5 inches of VACUUM. The vehicle is tuned well and dead nuts stable under boost. It’s just in that area of low vacuum, just below boost where I think I’m hearing it. It’s not continuous; just tick, tick, tick, now and then. Of course, if I let off or if I tip into the boost I think it goes away.
So what if any definitive measures can I employ to determine if I am encountering pre-ignition? As I understand it, the knock sensor is disabled on my application. My scan tool, AutoTap shows a knock retard data item, but it doesn’t seem active (I see no values). I’ve watched the spark advance when operating in said range and I’ve got a decent amount of advance 7-10 degrees. Of course this drops off to –4 or so as soon as I get in the boost.
What does the board wisdom sayeth?
__________________
Business: an ideal predicated on the money-making notion that there are no human beings, just human resources.
  #2 (permalink)
Old 03-09-2004, 07:35 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Looks like you might have a "tip-in" retard problem. You may need to pull another degree or two of timing at that point.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
Tags
detecting, pinging
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
