1978 truck dies after warming up
Hi, Just bought a 1978 ford F150 Custom with a 351M motor. It has sat for a year. Cleaned out the gas tank, new gas and fuel filters, new cap and rotor. Truck starts up good and runs about 10 minutes, then it dies like the key was turned off. I know the gas isn't the problem. It loses spark when it warms up. I need to determine what is wrong. When warmed up, it only sparks once as the key is turned and not while cranking. I think it is the brain box, pickup in the distributor, or the coil? Any way of checking any of these? Best guesses on what to replace first? Also, does the distributor have to come out to change the pickup? Thanks! John
the distributor can remain in place. after removing the cap and rotor. the armature is located with a roll pin. the armature will slide off the distributor shaft, with either a lifting action or very delicate pry action with a couple of screw drivers. the next part that needs to be removed will be the armature stop ring and the wire retaining clip. you will also need to remove the retaining clip that retains the vacuum advance arm. the stator assembly lifts out, but be sure to detach the system ground screw located where the leads exit the distributor housing. welcome to fte and good luck with the distributor.
DIY-ER
49
05-07-2018 09:26 AM
pkupman53
09-20-2015 10:57 PM
Darnoc76
09-16-2015 12:30 PM
pkupman53
32
08-30-2015 07:09 PM
