sputter at low rpm's - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-08-2004, 06:47 PM
phish19 phish19 is offline
phish19 is starting off with a positive reputation.
the past couple days my truck sputters at low rpms. only while in a gear though. while in nuetral it never happens just pulling out and shifting if the rpms are low enough when i shift. change the spark plugs a couple of weeks ago. for some reason i dont think its a electrical problem even though my battery light is on. had my altenator checked and it fine.
Old 03-08-2004, 09:17 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
I would repair the problem with your charging system, low voltage could cause many odd problems.
Old 03-08-2004, 11:10 PM
hreed hreed is offline
hreed is starting off with a positive reputation.
Wha year is your truck? I agree with Ken, if the battery light is on, something is wrong, even though the alternator checked out. A quick check is to see what the voltage is on the battery with the engine off. It should be about 12 volts plus or minus. With the engine running it should be about 14. You can check it right on the battery terminals. If it isn't electrical, I would suspect fuel problems.
Old 03-08-2004, 11:12 PM
Sorry about the misspelling. I punched the "submit" button too quick.
Old 03-09-2004, 08:40 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Hreed... you can press the 'edit' button within 1 hour ( ?) and make all the changes you want, even delete your reply! Cool site, huh?
tom
Old 03-10-2004, 02:28 AM
i think that it might either be the fuel filter or something with the carb. because it only does it in gear not in nuetral.
Old 03-10-2004, 06:11 AM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Quote:
An ignition problem will be worse under load also. Did you change your plug wires when you changed your plugs????
Old 03-10-2004, 08:41 PM
i noticed the spark plug wires and all that had been changed recent even though they're the exact fit brand. while i was looking over all of it today i did notice that one of the distributor cap screws wouldnt tighten down so i rigged something up so it would be down like a screw was in it, so thats something that has to be replaced.
1999 Explorer Transmission problem? kswasko8896 Explorer, Sport Trac, Mountaineer & Aviator 3 03-04-2015 04:45 PM
Sputtering 84 dylancroghan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-13-2014 02:58 PM
Missing and sputtering at 55-65 mph low rpm Dunatic 6.0L Power Stroke Diesel 9 05-02-2012 10:40 PM
97 Exp Check Eng,4x4,Low Range,O/D lights blinking. Engine sputtering. Missing 3rd? cardboardcamper Expedition & Navigator 10 03-19-2011 01:54 AM
408 sputters at high RPMs TheBlueMule 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 11-16-2008 12:40 AM
Tags
2004, 54, engine, escape, f150, ford, load, low, rpm, rpms, spuddering, sputter, sputtering, sputters, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
