Who has pulled their oil pan and found it clean?
Originally posted by BandBFord
Sludge is basically a thing of the past. Quaker State was the big culprit for years. The oil had a pariffin base additive (wax) that built up inside engines over time. My first engine rebuild (over 20 years ago) was a Ford, heck I can't even remember what size it was. I do recall that the owner was a die-hard Quaker state fan. When I removed the valve covers I could not believe what I was seeing. Then engine had so much build-up in it that I could barely see the tops of the rocker arms.
I just started my project, a 73 f100 w/ 360. It was in the family from new, and I KNOW it was abused. I took that monster apart and literaly used a gasket scraper, stiff brush, degreaser and pressure washer to get the junk off it before I could tank it. (after tanking the heads and finding it didnt come off, I had to try cleaning it first) The sludge was everywhere and baked in so it was almost as hard as the cast iron. I was happy the holes were not worn, so it didnt need to be sent out for machining.
Everything is clean now, and my parts arived (thanks UPS) yesterday, now time to find the time to throw all those parts into the block.
I just had apart a 1986 Olds with 3.8l V6 to put a new timing set on it. The engine just turned a 100,000 miles. Granny owned it and did many short trips Grampa changed the oil every 3000 miles. There is alot of caked on crud in the valve covers, but the oil pan looked pretty clean expept for all the plastic and metal shavings from the plastic timing gear. I think short trips are the worse thing, no matter how often you change the oil.
on
1 Post
Originally posted by c_rossman
There is alot of caked on crud in the valve covers, but the oil pan looked pretty clean ...
on
1 Post
I would think you would always see more sludge on the heads than in the pan because of the higher heat and less oil flow. Oil likes to pool in the heads and boil off.
I don't know if there was anything special about mine. I did 3k oil and filter oil changes and at that time I used Quaker state 10w30. I expect later when I started having some blow-by at 160k, it may have started to sludge up, but before that it was clean. I do remember while in the shop the one time, they had a T-bird with the intake manifold of and that thing was full of sludge. Had not been taken care of.
MGarner
08-17-2020 12:11 PM
cwatkin
03-31-2012 12:52 AM
rusty70f100
General Automotive Discussion
03-15-2004 12:50 PM
