clunking/popping noise from front axle? - Ford Truck Enthusiasts Forums
Old 03-08-2004, 01:15 PM
95f150's Avatar
95f150 95f150 is offline
95f150 is starting off with a positive reputation.
I have a problem with something clunking in the front end of my truck, it almost sounds more like a popping noise. Could this be something ready to break in my axle? Possible U joint? Shocks? It has been happening for about a week so i cant be sure when it happens but i think it happens when i make a fairly sharp turn at slow speeds.
Thanks
Old 03-08-2004, 01:22 PM
moose94's Avatar
moose94 moose94 is offline
moose94 is new and has a neutral reputation at this point.
does it happen when you are in 4WD? Cause if so then you have a bad u-joint somwhere inside the axle.
Old 03-08-2004, 02:08 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
A better question might be...does it happen only when the hubs are locked....or does it happen only when the hubs are locked and in 4wd? The more specific you are the better response you will get from us
Old 03-08-2004, 03:15 PM
Jarrett T Jarrett T is offline
Jarrett T is starting off with a positive reputation.
Check your tranny mount. I had this and the tranny mount bolt had broken and it was mainly when I was turning. I looked all over the front end trying to find it and........ Let me know.
Terry
Old 03-08-2004, 03:33 PM
95f150's Avatar
It clunks in 4x4 and 2x4. Hubs locked or not, no difference
Old 03-08-2004, 04:09 PM
Jack the front wheels off the ground and check the ball joints and wheel bearings, make sure the wheel is nice and tight.
Old 03-08-2004, 04:15 PM
95f150's Avatar
Here is what i replaced on my truck 3 months ago
-ball joints
-wheel bearings
-tie rods
-steering box
-brakes
-coil springs
-shocks
-tires
-radius arms
-Every hydraulic clutch component you can think of
Jumping your truck will cause this
Old 03-08-2004, 04:34 PM
JohnnyRodney JohnnyRodney is offline
JohnnyRodney is starting off with a positive reputation.
Ive got a 93 f1504x4 doing the same thing?I thoght it was ball joints ,Dont know??
Old 03-08-2004, 10:50 PM
FordPerf300 FordPerf300 is offline
FordPerf300 is starting off with a positive reputation.
Same thing on mine to, if i turn the wheel all the way to the left then a little to the right it makes a loud pop. I'm starting to think it's my steering box..
Old 03-08-2004, 11:29 PM
94F150-408 94F150-408 is offline
94F150-408 is starting off with a positive reputation.
Same thing here, and I dont have a clue. I've put on new upper and lower ball joints, wheel bearings, radius arms, wheels, tires and tie rod ends. Still pops...
Old 03-08-2004, 11:57 PM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
Check the rivets holding the front crossmember to the frame, I would bet they are loose. It is a fairly common problem that will cause the popping during low speed turns just like you describe. Get under the truck and have somebody you trust turn the steering wheel back and forth. Watch very carefully where the crossmember meets the frame. Mine moved around 1/8" to 1/4". While you are under there, check the crossmember itself VERY carefully for cracks around and above the axle drop brackets. You didn't say what brand of lift you have, but the Tuff Country lift that was on my truck when I bought it caused some major cracks. Cost me some serious $$$ to get everything welded up.
Old 03-09-2004, 12:08 AM
multi-yr.F150 & F250 multi-yr.F150 & F250 is offline
multi-yr.F150 & F250 is starting off with a positive reputation.
I had two 93 F-150's that made the same sounds. Popped when turning and when going into driveways. It was the rivets holding the crossmember just behind the motor. Start your motor but leave it in park then turn your steering wheel all the way in one direction then all the way back the other. If you hear the poping then have someone turn the steering wheel again while you look under the truck at the cross member between the door and the motor and you will see it move ever so slightly. If you can't see it then you can feel it move. If it doesn't pop just by turning the steering wheel while sitting still, in park it will when the rivet wares somemore. The solution is to have it reriveted or welded. I was told that the weld would brake after sometime so I had mine reriveted at a bodyshop, Stop the noise immediately.
Old 03-09-2004, 05:46 AM
My frame is cracked and welded too,Sorry lift kit.I had a Skyjacker lift on my other truck with no problems.I guess its time to look at rivets and weld joints????
Old 03-09-2004, 08:23 PM
Does having the TTB affect the popping? I have a solid D44 under my F150 and it still pops, i don't think the frame is cracked but the rivets could be loose...i'll have to check that out...how much would having the crossmember riveted run me?
Old 03-10-2004, 08:01 PM
Tylus's Avatar
Tylus Tylus is online now
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
both my Bronco and my F-150 popped as described and they were both due to a bad radius arm bushing. The bushing is split into 2 parts, the forward and aft part. In both cases, the forward part had disentigrated, but still looked fine when I crawled under the truck. I only found the problem when I installed the lift kits and was replacing the bushings. They retail for about $10.00 in town and even if they don't need replacement, the aftermarket ones are a ton better than the stockers.
Steering Clunk, I have no idea. bubba.whit6.4 6.4L Power Stroke Diesel 10 06-28-2016 10:42 PM
Clunk noise when going over bumps PokerMunkee 1999 to 2016 Super Duty 8 06-02-2016 07:45 PM
Front Drive Clunking Noise xSgtRenegadex Expedition & Navigator 16 08-15-2014 12:03 PM
Strange clunking on deceleration Red-Tail Ranger & B-Series 4 12-24-2012 01:07 AM
Turning Clunk When Wet? johnanderson Brakes, Steering, Suspension, Tires, & Wheels 2 12-04-2003 01:06 AM
Tags
axle, clunking, front
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
