running fog lights with high beams
The switch is not where the change has to be made. I've installed fog lights on previous vehicles and in the instructions it has the power leads tapped into the low beam circuit, so that when you go from lows to highs the for laps drop out. You'll have to get a wiring diagram for your truck and see where to make the changes. Remember if you connect into the high beam circuit the fogs won't work on low beams. Only way to do it that I can see is to put another switch in the dash board and attach directly to the battery, in that instance you'll have to remember to turn the fogs off.
Good luck,
Steve R
'99 F250 4x2 CC LWB 5.4L 3.73
Good luck,
Steve R
fat cat
2004 - 2008 F150
36
11-23-2007 02:02 PM
