clutch size
You should be able to use the 11 inch clutch no problem...
The flywheel should be drilled for the 10 and 11 inch clutches..
On E-Bay there is clutch pressure plate and flywheel combinations going for only $75.00. The guy sells 10 at a time ..
I got one ...ALL Ford parts... Excellent deal in my opinion....
They come with a NEW flywheel, NEW clutch disc, NEW pressure plate, NEW Flywheel bolts and NEW pressure plate bolts!!!!
For $75.00 thats a good deal..
BE SURE TO REPLACE THROWOUT AND PILOT BEARINGS TOO!!!!!!!!!
ftwfred
ftwfred
The following users liked this post:
greglatvala-msn-com
E-Bay Item number: 2457645700
QUOTE
"""New flywheel & clutch for a 300 Ford inline 6 cylinder. Has an 11" clutch disk, comes with bolts for pressure plate and bolts for flywheel. These are brand new Ford parts they still have part numbers on them. As far as applications these will fit all years. 300 Fords always used the same diameter flywheel with 164 teeth. For the clutches there were two diameters 10" or 11". The larger one is a heavier duty clutch but either will fit inside any bellhousing and use the same spline to fit onto input shaft of transmission. So this could be an upgrade depending on what your truck has now.""""
This auction has ended but he has them on there all the time....
E BAY AUCTION
Send him a message through E-Bay and he will reply, Maybe notify you of the next auction...
Oh yea, $25.00 for shipping
ftwfred
QUOTE
E BAY AUCTION
ftwfred
Amen to that. I often said that you needed to know what color underwear the guy that assembled your Ford was wearing that day to get the right part. The 81 F100 that my current tranny came from also had an 11". I would have thought that the light duty applications would have had the 10, but apparently the 11 is more common.
hayden01
04-26-2013 09:27 PM
mtfleming11
11-25-2012 01:00 PM
Midnite Cruiser
05-22-2006 12:12 AM
highboy 74
01-03-2006 12:58 AM
