oil galley plugs - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
oil galley plugs
Old 03-07-2004, 10:30 PM
pdkloste pdkloste is offline
pdkloste is starting off with a positive reputation.
oil galley plug leaking.. need advice
I'm fighting the oil leak issue which seems to be a common thread in this forum! Oil galley plug on driver side is leaking. Just wondering what size the driver is for it, can't get any of my 1/2" drives into it.... could be the angle of the engine to firewall... any suggestions?
Should this plug be taken out and sealed, or just tightened up?
Thanks in advance!
P.
97 PSD
Old 03-08-2004, 08:24 AM
mjwhip2 mjwhip2 is offline
mjwhip2 is starting off with a positive reputation.
A buddy of mine had the same problem. What he ended up doing was drilling a hole through the firewall and accessing the plug from inside the cab with a couple of 1/2" extensions. Turns out it was a bad o-ring on the plug. Not exactly the way I would want to do it but late saturday night in utah means 2 days until anywhere opened to get the right tool for the job if there is a right tool for it. But you gotta do what you gotta do to get the job done. If memory serves me correct there is and o-ring and a paper type gasket on the plug and if one is hosed there isn't much of a possibility of just tightening it fixing the problem. BTW it was a real pain in the a$$ getting the truck started after removing the plug, and he was told that he had to run the truck for something like 2000 rpm for 20 minutes or so to get all the air out of the rails to get it going like a champ again.
Hope it helps but it is 6am and I'm not thinking too well yet.
Mike
Water/oil leak Resurrected 56 F100 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 06-06-2015 12:18 AM
Bad Head Gasket, Coolant in Lifter Galley, Advice Needed warren561 1987 - 1996 F150 & Larger F-Series Trucks 0 09-24-2014 09:19 AM
351 Cleveland help 51 F3 owner 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 09-04-2014 12:27 AM
Engine help 51 F3 owner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 08-06-2014 03:40 PM
Oil galley plug? fmc400 Ford Inline Six, 200, 250, 4.9L / 300 3 01-26-2014 01:03 PM
Tags
400, 50, 73, change, diesel, ford, gallery, galley, leak, location, oil, plug, plugs, powerstroke, psd, rings
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
