I just aquired a 1963 Ford F-100 4X4 292 2bbl carb and a 4 speed. The truck runs but I think the timing needs adjusting but I don't have anything to check the timing since I don't know the firing order and if the timing needs to be set at 10 degrees or 12 degrees that is usually the norm. amongist ford engines.
Please help
I believe the rotor goes counterclockwise, is that right? I am replacing wires, cap, plugs, etc., & my firing order tags on my old wires came off in the process. Art
The rotor turns counter-clockwise on my 352. I'm not sure if a 292 is the same. The rotor generally turns in the direction that the tube on the vacuum advance points into the distributor.
