Crankshaft pulley removal on a 1950 flathead 8 - Ford Truck Enthusiasts Forums
Old 03-07-2004, 12:28 PM
palehorse13 palehorse13 is offline
palehorse13 is starting off with a positive reputation.
Question Crankshaft pulley removal on a 1950 flathead 8
I am helping a friend restore a 1950 F5 pickup which spent the last 53+ years as a fire truck in South Dakota. It only has 3000 miles on the clock. It is his plan to turn the truck into a regular F5 pickup and put a utility body on in place of the old 400 gallon tank.
In any case the thing that is giving us fits right now is that we would like to replace the front seal on the motor but we dont know how to go about removing the crankshaft pulley. We do not have access to the Ford tool shown in the 50 shop manual. The seal does not appear to be leaking now but I would rather deal with it now with the motor out of the truck than wait for it to fail later. Even with only 3K on the odometer, seals tend to dry out after 53+ years. Any thoughts about how to make/adapt such a tool would be appreciated.
Front Crankshaft Seal Replacement Help packagerjr 6.0L Power Stroke Diesel 4 10-15-2016 02:57 PM
Rear Seal Replacement- Stuck in engine repair hell! fusionstate 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-25-2015 12:31 AM
crankshaft seal f350project 6.0L Power Stroke Diesel 1 03-02-2013 07:15 PM
Help with 2004 F-150 Crankshaft Pulley jrroth 2004 - 2008 F150 0 04-30-2012 01:21 AM
C1AE-6A312-C crankshaft pulley 46yblock 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-24-2010 07:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1950, 30l, crank, crankshaft, escape, f100, flathead, ford, front, pulley, pully, removal, remover, tool, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
