Firing Order on 360 - Ford Truck Enthusiasts Forums
Firing Order on 360
Old 03-07-2004, 12:46 AM
jandecrider jandecrider is offline
jandecrider is starting off with a positive reputation.
I need your help !!!
I just reciently rebuilt my engine on my 1977(f250,360 engine) Ford Truck and I want to know if anyone can help me with a problem I have...........I need to know the timing order on the distrubuter cap with electronic ignition.Any help would be greatly appreciated. thanks !!
Old 03-07-2004, 01:53 AM
68back 68back is offline
68back is starting off with a positive reputation.
Are you sure that you have a 360,my book does not show a 360 in 77.the firing order for 351w,351m,and 400 is starting with no.1 and going counter-clockwise,1,3,7,2,6,5,4,8.For 302,and 460 it is 1,5,4,2,6,3,7,8.
Old 03-07-2004, 02:04 AM
I took a 73 engine and put a 77 electric distrubutor in it.
Old 03-07-2004, 02:10 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Firing order will be the same as the original points type ignition for your 360. The cam and crankshaft determine the firing order.
Old 03-07-2004, 12:47 PM
bob arrington bob arrington is offline
bob arrington is new and has a neutral reputation at this point.
it should be on either the front or back of the intake if it is stock,bob
Old 03-07-2004, 01:15 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Old 12-15-2013, 05:31 AM
danhandled1 danhandled1 is offline
danhandled1 is starting off with a positive reputation.
Smile I also have a 77 with a 360,
I also have a 77 with a 360, Mine is a f-150 ranger short bed 4x4, and every time I go to the parts store, It's either argue with them for 15 min, or order my parts for a 76,,,
Old 12-15-2013, 08:25 AM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
You probably already know this but cylinder numbering on Ford is different from Chevy and MOPAR. Suggest you verify you are using the Ford cylinder numbering scheme. Don't ask me how I know...
Old 12-15-2013, 09:33 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Avoid the argument and just tell them it's for a 76.
Help!!!! How to ID 360 vs.390 R202INT FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 05-24-2014 06:56 PM
360 and 390 heads istfordinmylife 1967 - 1972 F-100 & Larger F-Series Trucks 8 06-11-2008 11:33 AM
1976 4x4 360 to 460 swap gsalisbury 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-15-2006 08:34 AM
ford 1973 360 ci firing order warlordpigpen FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 10-04-2003 09:45 PM
HP / Torque of a 360??? nicebenz68 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 03-21-2003 09:42 AM
Tags
1979, 360, firing, ford, order
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
