D20E Heads - 302 - Ford Truck Enthusiasts Forums
D20E Heads - 302
Old 03-06-2004, 09:24 PM
w951wxj w951wxj is offline
w951wxj is starting off with a positive reputation.
D20E Heads - 302
Looking for any documented information on these heads. They are from a 73 F100 - 302. Looking for volumn and valve sizes.
Old 03-06-2004, 10:16 PM
mgoovaerts mgoovaerts is offline
mgoovaerts is starting off with a positive reputation.
I pulled the my heads off today D20E and I'm looking for the same info for my 72 mustang.
Old 03-07-2004, 11:57 AM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
well according to a book have it should look like this:
58 cc combustion chambers
1.78" intake valve
1.45" exhaust valve
port size intake 1.94" X 1.04"
............exhaust 1.24" X 1.00"
You could measure your ports and valves to see if they are the same as above, then you could be somewhat certain the cc is 58, but you should measure them to be certain. If you infact have the above heads, the ports are smaller than the 351w D0** eqivalent, just a thought, later
Old 03-08-2004, 07:58 AM
Thanks for the info. I did measure the ports and they do come out as you described. I had some documentation that stated 58.3 chambers but I had another source telling me 53. they probably just transposed the number. I just wanted some double check.
72 F-100 302 heads or engine Quentin10 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-27-2014 04:04 PM
86 mustang 302 into a 94 f150 with 302 my93 1987 - 1996 F150 & Larger F-Series Trucks 8 12-30-2010 11:50 PM
302 vs. 289 heads dogstar Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 21 11-11-2010 01:39 PM
351w heads on 302 Ford347 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 16 04-07-2007 08:36 PM
Boss 302 Heads GrimReaper Performance & General Engine Building 9 11-30-2001 04:24 PM
Tags
302, 73, block, casting, combustion, d20e, d20easa, engine, ford, head, heads, mustang, number, size, vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
