Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-06-2004, 04:07 PM
scottolan scottolan is offline
scottolan is starting off with a positive reputation.
Oil leak fixed... **Pics within!!!**
My sisters 5.4L Expedition was leaking like a sieve... OIL EVERYWHERE! So I crawled up under there and cleaned the area off and could see very well where the leak was coming from.
Called up Ford and talked to the guy, he said he knew exactly what I was talking about and that this is a frequent problem with both the 5.4 and 4.6! The part # is F6AZ*6840*BA and it was only 7.52 for the gasket... after pulling the part You could see exactly what the problem was. The old gasket is on the left and the new one is on the right... You can see that the raised area of the gasket is completely squished flat!!!
So it took all of about 30 minutes to actually replace the part.. not bad at all you will need a 3/8 ratchet, a 3/8 swivel, and a foot long extension. The bolts are all 10mm (I used a deep well.. it worked best since the bolts are kind of hidden) You WILL need to drain the antifreeze (I just drained them into a bucket - then dumped it back in when I got done) but you DON'T have to drain the oil.. all the oil drains back into the pan and the only oil spillage you might come up against is when you spin off the filter.
These next 2 are just pics of the adapter part for reference so that you can see where the bolt locations are..
On this one you can see a sligh casting flaw on the surface but it was ok since it was inside the gasket surface and didn't interfere with the seal at all
I hope this helps someone out on here
Scott.
__________________
1988 Ford Mustang GT (Auto)(Speed Density)(power everything)
14.02 @ 98.46
JBA Headers, Bassani Catted "X", Dumped Dynomax bullets, 3.55's (new times to come with built AOD w/converter)
  #2 (permalink)
Old 03-06-2004, 05:09 PM
prcrboy's Avatar
prcrboy prcrboy is offline
prcrboy is starting off with a positive reputation.
FYI,
I bet it was a '99 model. Ford had a problem at the engine plant on one of the milling machines and it was to say "out of spec." It is a known problem and you have found fords solution. However, not to be the bearer of bad news, but keep an eye on it! The new gasket sometimes lasts only a few thousand miles and it starts leaking again.
For more info.
http://www.ford-trucks.com/forums/sh...52B%25252Bleak
__________________
Project= '79 F150 Lariat 4x4, 460/C6
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems, "
  #3 (permalink)
Old 03-06-2004, 10:05 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Thanks for the write-up and pictures
I'm sure that will come in handy on here sometime.
I think I'll add this post to the FAQ's.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
