Help! need speedo drive pinion fo BW1345
I need to find a source for a speedo drive gear for a BW1345, in an 84 250,6.9IDI, T-19,3.54 gears. My local Ford guy says they are now made of unobtanium. The gear I need is the drive gear in the T case, everthing else, both cables the cruise con. thingy between the cables ck. out ok with the drill motor test.
Many Thanks ncshooter
i replaced mine about a month ago on my f150 with a 1345 and it was just like the one i took out, plastic gear on a steel bushing that is clamped between the yoke and the bearing. you just drop the drive shaft pull the yoke and speedo out of the top, pop out the seal and it should slide right out. i think it was right around $20 and the driven gear was $7 just dont forget to get a new seal to put in since you have to take the old one out.
Fordman300
Fordman300
twiin640
11-10-2014 10:22 PM
Pete Roberts
21
02-01-2014 10:27 AM
RayJay10
05-13-2010 11:50 AM
oldhalftons
07-11-2004 06:00 PM
