Radial TSL Swampers or Radial Ground Hawgs
OK. So I have narrowed the tire to either the Super Swamper TSL Radial (not SSR) or the Ground Hawg Radial. Both tires are 38/15.5-16.5 I don't know which to go with??? I've heard good and bad with swampers, but haven't heard anything about radial Ground Hawgs. Can you guys help? Thanks
I've never run the radial GoundHawgs, but I can tell you from experience that the non-radials are like most big mud tires, hard to balance, flat spots when they're cold, and extremely noisy! And in the mud they pull like nothing short of a tractor tire! They are directional, which means they'll get you into trouble that you might not be able to back out of! I bought my first set in 1980 and I still run them today, as do quite a few of the professional mud-racers! IMHO, it depends on what you want out of the tire. Trey Gorbett '78 F250-Bronco Hybrid 460,NP435,NP205,Dana60 front,Sterling 10.25 rear,4.10's, 17/40x16.5 GroundHawgs [a HREF="http://www.ford-trucks.net/users/bandit99/index.html"]SuperBronco[/a]
I don't do really any mudding. I want the tires for mostly pavement driving and an ocasional cabin trip or dune trip. I have a set of 39/18-16.5 Mickeys right now and want a tire that doesn't pull as much all over the road and a tire that isn't as bouncy as the Mickeys.
I'm not sure that I'd recommend either tire for your desired usage, both will dig aggressively in loose sand. The non radials are pretty bad about "tracking" the grooves in pavement and also wear pretty fast. You might take a look at the new 37" BFG's that are coming out, and I think Goodyear also has one at 37". I had a set of 35" BFG-Mud Terrains and were probably the best mannered tires I've had on one of my vehicles. Probably gonna put a set on the wife's F350 SuperDuty whenever I need new tires for it. Hope this helps, Good luck! Trey Gorbett '78 F250-Bronco Hybrid 460,NP435,NP205,Dana60 front,Sterling 10.25 rear,4.10's, 17/40x16.5 GroundHawgs [a HREF="http://www.ford-trucks.net/users/bandit99/index.html"]SuperBronco[/a]
The only comment I can make is about a set of Hawgs that a friend ran on his Blazer. After they got some wear on them, they rode and looked like sh#t. Really, they shook and bounced like crazy. They left a bad taste in my mouth ever since (not that I tried eating them...)
Bill McCall
'01 F250 Super Duty 4x4 Crew Cab Shorty V10 Auto 4.30ls
Fabtech 5.5" lift-all spring!, Weld Sidewinders,35" BFG MT's, RS 9000's, Velvet Rides
[link:albums.photopoint.com/j/AlbumIndex?u=1458111&a=10957692|WLDS V10 PICS]
Bill McCall
1989bricknose
06-15-2016 07:30 PM
f150light
08-30-2012 05:46 PM
wareagle8403
15
04-05-2011 09:49 PM
chadrock
23
11-11-2002 07:25 PM
