A4LD transmission problem - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 03-05-2004, 11:32 AM
bell47g2 bell47g2 is offline
bell47g2 is starting off with a positive reputation.
Unhappy A4LD transmission problem
My transmission just decided to quit working altogether.
As I was accelerating, the transmission acted like someone just put it into neutral. Nothing works forward or reverse.
I think I lost pump pressure suddenly. there was no other mechanical noise associated with it. No excessive metal is in the pan, just the usual black fine iron residue on the magnet.
Tranny has about 185000 miles on it.
Any help as to what I might look at will be appreciated.
Old 03-05-2004, 11:36 AM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
First, welcome to FTE!!!
It could be the torque converter also........
Old 03-06-2004, 10:06 PM
Turns out it is the torque converter splines that drive the gears ( the inner shaft splines) have stripped out.
I will probably rebuild the rest of it any way since it is out. Any recommendations on brand of torque converter and rebuild kits?
Old 03-07-2004, 02:40 AM
JTHill24 JTHill24 is offline
JTHill24 is starting off with a positive reputation.
bell47g2:
Bulkparts.com
Best parts and cheapest prices.
Have used them for parts for my two 4ALD rebuilds. Both transmissions still running great.
Transmission suddenly stop working jshmccal 1999 - 2003 7.3L Power Stroke Diesel 12 10-04-2015 09:16 PM
transmission problems tjromero Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-23-2015 11:15 PM
transmission rebuild question King Windsor III 1987 - 1996 F150 & Larger F-Series Trucks 4 04-21-2015 03:55 PM
400 to 351W motor swap adamssho 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-28-2013 06:38 PM
New Transmission Creep_E_Er 1967 - 1972 F-100 & Larger F-Series Trucks 7 12-15-2011 09:25 AM
Tags
4ald, a4ld, durham, ford, nc, problem, problems, pump, quit, rebuild, reverse, suddenly, transmission, transmisson, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
