Can you mix Mercon and Mercon V? - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 03-05-2004, 12:24 PM
fireball69 fireball69 is offline
fireball69 is starting off with a positive reputation.
Can you mix MERCON and MERCON V together? I had my trans flushed last week and want to change the trans filter now. The dipstick on the trans says use MERCON and when I took it in to Firestone to get it flushed the guy told me I needed MERCON V (a synthetic). The receipt does not say what fluid was put in.
Can they be mixed? If not, how can I tell what was put in without flushing the whole system again?
Thanks
Old 03-05-2004, 02:09 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Mercon V is not, by specification, synthetic. It is usually a hydroprocessed blend that is Dexron/Mercon/Mercon V. Unless you have an E4OD that specifically prohibits Mercon V, you are fine. Since you have a 4.6 4x2 F-150, you dont have the E4OD. There should be no worry about mixing Mercon fluids in your case.
GM has an ATF spec that is backward compatible to 1949. Why does Ford, and worse, DaimlerChrysler with "dealer only" +4, have to make it so complicated?
Jim
Old 03-05-2004, 03:20 PM
Thanks, it's good to know that I'm OK either way. The trans is a 4R70W. I'll change the filter tomorrow after work. Thanks again.
Old 03-07-2004, 09:17 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Originally Ford recommend using "Mercon" in the 4R70W out of the factory right up until 1997. That is why it's written on your dipstick. Beginning in 1998, "Mercon V" became the standard for that tranny.
However, I'm pretty sure that the Ford tranny guys changed their tune a few years ago and determined that "Mercon V" should now be used in the 4R70W tranny for ALL years. So maybe Firestone was actually on top of things by telling you that.
Old 03-08-2004, 10:57 AM
Rockledge's Avatar
Here is the source of my information about all 4R70W trannies now requiring Mercon V:
Tranny Fluid for the AODE-4R70W
Old 03-08-2004, 07:41 PM
Thanks Rockledge fir the information and followup. Used the Mercon V when changing the filter.
Old 03-10-2004, 09:52 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
General rule of thumb is that the upgrades are typically safe, just the newer version. Usually you can upgrade an older trans to the newer stuff, just don't try to put older oil into an newer trans, (like if you had a stockpile of it) Only exception is the older Type F tranny's, but then that's why it says type f, not Mercon.
Old 03-10-2004, 10:12 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Just dont try to put Mercon in a trans requiring Type F. Your intermediate band will go bye-bye in a big hurry. Trust me, I learned the hard way.
Old 03-10-2004, 10:33 PM
Rockledge's Avatar
You don't really want to use Mercon V in an older AXODE/AX4S tranny, either.
On the other hand, you should be adament about using it in one built after '97.
Mercon V vs. Mercon III AmmoDawg Expedition & Navigator 2 01-08-2013 10:26 AM
Can You Mix Mercon V with DexronIII/Mercon? tonyford Escape & Escape Hybrid 8 11-30-2010 12:21 PM
mix mercon and mercon v whatstar1117 Aerostar 3 11-18-2009 05:47 PM
With Mercon Phasing Out, Can we Use Mercon V ? JFUSION Escape & Escape Hybrid 5 11-21-2006 09:34 AM
Mercon vs. Mercon V...again. horseman1956 1999 to 2016 Super Duty 19 08-27-2006 11:49 PM
Tags
1715, 1994, 2004, 4r70w, f250, fluid, ford, mercon, mercron, mix, mixing, safe, superchips, taurus, transmission, type, v, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
