Substitute for brake fluid
on
Can anything be used as a substitute for brake fluid. When I pull the 52 home I'd like to have brakes. I should have the emergency brake but just would also like the brakes too. I don't want to spend $32 for 4 litres of brake fluid if I'm not gonna be using the brakes ever again. Any sugestions?
Nathan, it holds four liters? Wow! How about if you only filled it half full just for the one trip? Or is it 4 litres because you have huge brake cylinders on there. Also, be advised that brake fluid is water based, so you cannot add any alternatives that are petrolium based. Just a word to the wise, if you know what I mean. How much would it cost for a tow? $32 would go a long way towards that, I would think. Then you could be at home making all the repairs instead of trying to make it road worthy where it is now. Good luck, John
on
Of the trucks I have had they were bone dry. 4 litres would probally just fill the system. It's cheaper to buy more. 1 litre is like $9 but then this is the good dot 3 stuff. It would cost me $70-90 to get it towed, I can't put it on the trailer since it just fit the F-1. I pulled my M-3 home with just the emergency brake but then we didn't have to go through a valley. I wonder if motor oil would work? I don't think that compresses. We got alot of used stuff.
on
Hmmm... Since I've never seen the truck yet so I don't know the condition of the brakes. Barry the worst damage I could do is hitting our truck or running through a ditch into a barb wire fence. The truck is not gonna be pulled through town and most likely the place to hit the fence would be our own property since we own the land in the valley. Also what would a towbar help?
The following users liked this post:
Recycle
