Twin I-Beam Camber Adjustment - Ford Truck Enthusiasts Forums
Old 03-04-2004, 09:25 PM
Boltgunner's Avatar
Boltgunner Boltgunner is offline
Boltgunner is starting off with a positive reputation.
Maybe I am the last one to figure this out, but an outfit called Specialty Products Co. (www.specprod.com) sells these cool spacers outta aluminum so you can adjust your spring length so you can pull outta the negative camber world. Just thought I would pass it on, ya'll take care!
Old 03-05-2004, 12:45 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
The company website lists caster adjustment bushings but no camber adjustment.
Old 03-05-2004, 08:06 AM
Boltgunner's Avatar
I think in the hard copy version of the catalog (saw one at a Car Quest store yesterday) they speak of camber adjust in the spacer section. I have a copy on order and will report back when I see it. I need about a degree and a half of positive camber, and doing some trig (inverse TAN rise over run) I added 1 inch of spacer to a 36" approx. arc and got close enough. The 36" was a wild *** guess measurement from the I beam pivot point to the bottom of the spring center.
TTB f-250 1995 camber. mightymoose95 1987 - 1996 F150 & Larger F-Series Trucks 9 01-06-2014 03:30 PM
Ball joint sleeves for 2.5 lift smoky_diesel 6.7L Power Stroke Diesel 9 09-22-2013 09:02 AM
ford f250 camber sleeve over 3 degrees camber caindog110 1987 - 1996 F150 & Larger F-Series Trucks 0 05-21-2013 09:42 PM
Question re: 1990 F150 4x4 alignment quaddriver 1987 - 1996 F150 & Larger F-Series Trucks 4 03-23-2009 04:29 PM
adjust camber Seifferlein 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-29-2003 01:53 PM
Tags
1973, adjust, adjusting, adjustment, beam, camber, caster, chamber, f100, ford, ibeam, ibeams, kits, negative, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
