Are the 8 hole wheels interchangeable between brands of vehicle or are they specifically made for each make. Can i use my wheels on a chevy or a dodge 3/4 ton
thanks a lot for any replys
I am not sure about the newer pickups.But I do know that in the 80's models a Chevy or GMC rim would NOT fit the Fords because the center hole was too small on the GM rims, but, the ford wheel would fit the GM's, as far as dodge...don't know, but I would say that most likely they would work. The lug bolt pattern and spacing is all the same on all of them
Not all wheels are interchangable, they have different lug spacings. You'll have to check the lug spacing on your truck and the wheels that you want to swap for.
