Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2004, 04:20 PM
Tattoo Matt is starting off with a positive reputation.
my 302 h.o. is stalling when it's washed
well i'm usually asking questions about my 76 ford truck..but this time my my question is about mt 90 mustang..I just took the car out of storage ..had a new tranns put in it and got it ready to drive.. after tinkering with it i took it out for a spin to test the new trans and it worked fine. Then I went to the car wash to cleen the car..after I was done my car didn't start...I ended up flooding it out I cleaned a few plugs ..then it started and ran kinda funny...then after a day it ran like normal...2 days later I did the same thing..cleaned the car..left it running..and it stalled while cleaning it ..after about 20 min. it started and made a very loud pop(like a gun shot).. then it drove funny(some backfiring and missing after about 3000 rpm) after about 2 hours it drove fine.. I know my wires are in the right order....not shure what going on...any help would be greatly appreciated!! thanks tattoo Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2004, 05:09 PM
Mike G is starting off with a positive reputation.
Sounds like you are getting moisture in your ignition/spark system. Sorry I am not familiar with the Mustang (let's talk about that truck) but you should check around the dist cap/spark module for loose wires/connections and the such.
--Mike G
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #3 (permalink)
Old 03-03-2004, 05:59 PM
Ecuri is gaining momentum as a positive member of FTE.
I agree with mike but more specifically would pull the dist cap and see if it does't have some condensate inside.
__________________
78 F150 408 4v valves/C6
77 F250 390/NP435
99 Explorer daily driver
  #4 (permalink)
Old 03-03-2004, 07:19 PM
do you think that just the moisture and not direct water on the distributer would cause this..becouse both times i washed it the hood was closed...i thought that maybe it could be my computer getting wet also...thanks for the replies!!
  #5 (permalink)
Old 03-03-2004, 07:56 PM
atticmole's Avatar
atticmole is starting off with a positive reputation.
I had a car with an invisable crack in the distributer cap, gave me FITS!! It would even look dry inside. After blow drying the cap fixed it in a few minutes, I caught on and replaced it. solved my problem.
__________________
Larry
Brutus - 1960 F250 CC Flatbed Ford
Y-Block 292
  #6 (permalink)
Old 03-03-2004, 10:07 PM
Thomsen is starting off with a positive reputation.
you are definitely getting moisture in your distributer.
__________________
1970 Highboy 4X4: 466, NP-435, Dana 60's, 42'' Iroks
1978 F-150 swb 4X4: 400, NP-435, 205, 35" Mudders
1979 F-150 4X4: 466, C6, 203, 38.5" Boggers
1986 F-350 CC 4X4: 6.9 IDI, T-19, D60/Sterling
1989 F-350 4X4: 7.3 IDI, ZF-5spd, Banks Turbo
1994 F-150 4X4: DD, 5.0, AOD
  #7 (permalink)
Old 03-03-2004, 11:38 PM
atticmole's Avatar
I forgot to add the cracked cap was kinda new, One reason I took so long to replace it. It would act up sometimes just going thru a small puddle or light rain. Hope your problem is as cheap a fix.
__________________
Larry
Y-Block 292
  #8 (permalink)
Old 03-04-2004, 09:56 AM
BandBFord's Avatar
BandBFord is starting off with a positive reputation.
"Tattoo" If memory serves me correctly the Mustang coil is located on the drivers side fender/shock tower? You could easily have a cracked coil tower which allows the water to become a conductor for the spark instead of the coil wire. I doubt that you are getting water in the distributor if you are not washing under the hood when cleaning your car.
I know this seems old school however, get yourself a plastic spray bottle (dollar store kind will do). Fill it with water and wait until dark (or pull it in a garage {vent the exhaust}) with the lights off. Start the car and light spray the coil, coil wire and distibutor cap with a fine mist, if you have a crack it will show up. Also, listen for it, you can hear voltage "jump" when a crack is present. When you find it, don't touch it to see if it is real. It will hurt. Then simply replace the part...
Oh... one last thing, keep body parts (and clothes) away from moving car parts.
__________________
B and B
2006 F-150 5.4 "Chrome Edition" SuperCrew 4x4
2006 Mustang GT
2001 Mustang V-6
1999 Mustang V-6
1996 Ford Explorer
  #9 (permalink)
Old 03-04-2004, 12:14 PM
thanks for the info ..will give those suggestions a try
  #10 (permalink)
Old 03-06-2004, 11:52 PM
Purdue Offroader's Avatar
Purdue Offroader is starting off with a positive reputation.
not positive but won't spraying wd-40 on the dist be a cheap easy TEMPORARY fix? Or would that totally screw up the dist (my gf's dad's dodge won't start when it rains so I suggested it to him but he can't even find the dist.........then i suggested he buy another ford........haha he drives his wifes expedition when his truck doesn't work)
__________________
'79 F-150 351M.... Check out PORC.Purdue.Org Purdue Offroad Club
  #11 (permalink)
Old 03-07-2004, 01:29 AM
DW2455's Avatar
DW2455 is starting off with a positive reputation.
yep WD-40 works wonders any time i go to the car wash to clean my engine i take a can of WD-40 and a dry paper towel and soon as im done i pop the dist. cap dry it with the paper towel shoot a light ,mist of WD on the inside of the dist. and the cap put it back on and take off with no problems. Good luck DW
__________________
MY Web site have A L@@K
  #12 (permalink)
Old 03-07-2004, 01:40 PM
swann79's Avatar
High-tech Redneck
swann79 is gaining momentum as a positive member of FTE. swann79 is gaining momentum as a positive member of FTE.
yup... Read the can... WD-40 stands for Water Displacement formula, #40. This is what that stuff was made for!
__________________
*Scott*
2001 F-250 CC, SB, Lariat, 4X4, 6.8 V-10... "BSEG Club"
17 other Fords '62-'05, Trucks, SUVs, Vans, Mustangs... all sold or dead!
  #13 (permalink)
Old 03-07-2004, 04:46 PM
kickinhorse89 is starting off with a positive reputation.
Miss
I had the same problem with an 90' that I had. Although when it rained the car would not even start. The thing that worked for me was the actual Wire Dryer product that they sell...I traced it to the coil but replaced everything just to be sure...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
