Stripping a Cinder block wall - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 03-03-2004, 11:35 AM
95se5m's Avatar
95se5m 95se5m is offline
95se5m is starting off with a positive reputation.
Lo all. I have a cinderblock wall that needs to be stripped of old paint that's flaking and calcite deposits that have built up over the years. I need to seal this wall before the ground thaws out too much more. Because of the weather going from Frigid to beautiful so quickly my procrastinating has caught up with me.
I have considered using a wire wheel on a drill, but that is going to take forever. I need to do this quick so I can maybe get the sealer on this weekend, or one night next week.
Any thoughts or suggestions?
Old 03-03-2004, 05:08 PM
otto otto is offline
otto is starting off with a positive reputation.
sandblastings best, maybe pressure washer..........mayhaps muratic acid
Old 03-04-2004, 03:50 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Sandblaster and then seal it with UGL drylock.
Old 03-04-2004, 08:47 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
How old is the paint? More than 30 years old? May be lead-based. Be careful when sandblasting lead-based paint. I think they outlawed lead-base paint in 1978 or 79.
Old 03-04-2004, 09:17 AM
95se5m's Avatar
Quote:
I can almost bet it's older the 30, I could be wrong however. The paint is quite loose and alot has flaked off already. Thank you for the warning, I had not given that consideration.
Old 03-04-2004, 10:08 AM
Big Orn's Avatar
As long as it's your residence, then you’re fine. But, a commercial establishment is another matter (in some states). I wouldn't go stirring the stink over it if it's not a public place.
Just be sure there's no children around - they love the sweet taste of lead. Pets too. I would also put some visqueen down to catch the waste. You wouldn’t want it leaching into your garden, if you have one. In sandblasting lead-base paint there is potential to have 2500 micograms of airborne lead at any given point. With that amount a Full-face air purifying respirator is recommended. I suppose you’ll have supplied air anyway with a sandblaster.
Chemical strippers are messy and a last resort – also hard (headache) to get rid of the waste since it will be considered hazardous waste.
Scraping is the best, but also time consuming and hard work.
Rotary brushes are slow, too.
Just do the job and be prepared, the less publicity the better – if the paint on it is 1978 or older.
TECH: Rear Cab Wall Stiffening CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-08-2014 04:49 PM
Wide White Wall needed Jag Red 54 N. California Chapter 11 11-21-2006 08:58 PM
Air Line System For Garage e william Garage & Workshop 120 10-26-2005 01:46 PM
Air line layout tgregoire Garage & Workshop 30 10-31-2004 01:14 AM
Any contractors out there? -Partition wall question. maa139 General NON-Automotive Conversation 8 09-29-2004 11:11 PM
Tags
acid, block, cinder, cinderblock, drylock, flaking, garage, paint, removing, sandblast, sandblasting, strip, stripper, stripping, walls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
