Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-03-2004, 08:33 AM
MatthewLebeau MatthewLebeau is offline
MatthewLebeau is starting off with a positive reputation.
61 Econoline Engine
I just purchased a 1961 Econoline truck this past weekend. It has a 262 engine in it, which I don't beleive it is the original.
Is this engine in the same 144/170/240 family? Are things like valve covers, oil pans, manifolds, etc. interchangable?
  #2 (permalink)
Old 03-03-2004, 07:53 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
sorry, never heard of a 262 engine. 144/170/200 are the only bolt ins for the econos. 250 will fit with some work, it is wider and taller. parts will interchange between the smaller sixes, some will interchange between the smaller sixes and the 250. take a look at my gallery and look at my econos. post a few pics of yours. send me the data plate info and i will decode it for you. i need all three lines from the data plate. glad another one is still around.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 03-03-2004, 10:50 PM
Jimbare's Avatar
the 240/300 engines are a differant family altogether. 144-170 are the stock engines 1961-1965. 240 came in 66-67 models. there is the very rare 200 in 65-67 models. only one in the data base. is you truck a 3 speed?
__________________
jim
  #4 (permalink)
Old 03-04-2004, 10:43 AM
Thanks for the reply!
This van was an eBay purchase. The previous owner stated it had a 262ci engine (which I never heard of either). I have yet to look at the block numbers as I am going to pick it up this weekend.
I looked through an old "Mac's Antique Auto Parts" catalog (http://www.macsautoparts.com/pu.html) and found a reference for a 262:
Model: 262
Cyl: 6
Years: 63-64
Liter: 4.3
B/S: 3.718" x 4.030"
HP: 132 @ 3600
Torque: 224 @ 1300
Cmpr: 8.00
Comments: Ford Pickup Truck
If this engine is as obscure as it seems, I might do well in the long run to start keeping my eyes open for a decent 144/170.
  #5 (permalink)
Old 03-04-2004, 10:54 AM
Not sure how to post photos to the gallery. Any suggestions?
  #6 (permalink)
Old 03-04-2004, 11:11 AM
Nevermind - I figured it out. I posted a front and side view of the truck. The body looks great, but the interior is pretty rough.
I'm going to pick it up from Portland, OR and take it home to Seattle, WA this weekend. (appx 175 miles) I'm going to replace the worn fan belt, plugs/wires, and gas filter before leaving. Finding the right parts - assuming it is a 262 - will be tough.
  #7 (permalink)
Old 03-28-2004, 11:15 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
The 262 is a larger and heavy duty version of the 223 that dates back to 1952 as the 215. The 262 has a higher Iron content in the block ten the 223 and 215. the Head uses the same valve sizes as the 223. This engine was mainly used in the medium duty trucks but also offered in the f-100 and f-250 from 1962-1964. Good solid engine.
Dan
  #8 (permalink)
Old 03-29-2004, 09:23 PM
Dan...
Thanks for the info. I got some great data from some others on this forum and they were able to confirm that I in fact don't have a 262. The big tip off was that the intake/exhaust manifold on the 262 in on the drivers side. I asked the guy I bought the van from what made him think it was a 262 and he told me was told that when he bought it.
It turns out that the engine is a normal 144 or 170. I'm still not sure how to determine which one of the two it is.
...Matt in Seattle
  #9 (permalink)
Old 03-30-2004, 02:58 AM
ke6bnl ke6bnl is offline
ke6bnl is starting off with a positive reputation.
Quote:
Originally Posted by MatthewLebeau
Dan...
...Matt in Seattle
The only way I know for telling if it is a 144 or a 170 is to determine the stroke, I did it with a piece of welding wire to measure the stroke but I don't recall the number differences, if I can find them when I get home I will post it. Ed ke6bnl try this site that is were I got the information Ed ke6bnl
http://autos.groups.yahoo.com/group/oldeconolines/
__________________
1950 F1 pu street rod 327, 700r4, 9" 3.50:1 posi
1963 Econoline pu 5 window
1970 chevy pu c10 sb & 4x4 sb
1949 F1 Ford PU v8 flathead stock v8 flatty
1953 Chevy 3100 Ad pu
1948 Ford F3 Pu
  #10 (permalink)
Old 03-30-2004, 10:24 AM
The 144 engine has a bore and stroke of 3.5x2.5 inches and the 170 is 3.5x2.94 inches. Both of these engines have 4 main bearings. The 200 and 250 cuin engines have 7 main bearings and a larger block. All four of these engines have the intake manifold cast with the head.
Dan
  #11 (permalink)
Old 03-30-2004, 02:32 PM
Ed...
Measuring the stroke sounds like a good idea. Where did you measure from? As Dan pointed out, there's just under a 1/2 inch stroke difference. If I take a measure from the sparkplug hole on the side of the block down to the top of the cylinder head, will the angle affect my stroke distance?
...Matt is Seattle
  #12 (permalink)
Old 03-30-2004, 05:10 PM
Wink
Ed...
...Matt is Seattle
This is the response I got from the econoline group from one of the econoline GURUS Jay LONG
In oldeconolines@y..., "J B Long" wrote:
Ed, sorry, but there's no way to tell the difference from the
outside, since
they both used the same block and head. Only the stroke (crank and
rods) is
different. If the engine has been repainted there's simply no way to
tell
without measuring the stroke. If you decide to do that, the 144 has a
stroke
of 2.5 inches, the 170 is 2.94. I've measured that with a piece of
welding
rod bent slightly and stuck down into the #1 cylinder. Start at TDC,
and
rotate the crank 180 degrees and measure again. The difference is the
stroke.
Jay (talking Econolines, thank you) in CA
Good luck it worked for me Ed ke6bnl
__________________
1948 Ford F3 Pu
Tags
19611967 , 1967 , 61 , 67 , econoline , engine , ford , photo , pu , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
