Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-02-2004, 08:56 PM
DR JOE DR JOE is offline
Garage is empty, add now
DR JOE is starting off with a positive reputation.
Propane injection
Is there anyone out there using Propane injection on there PSD??
I have been doing allot of reading on this subject and wondering if it's all that and a bag of chip's???...
If you do have one what brand?? And what did it do for you?? ie; better performance, mileage or both or what happened??
Do you recommend one???
Joe
P.S.
I would also like to say thank you to the people of this web site, as I have learned a lot from the great people on this site.. Please keep up the good work.
  #2 (permalink)
Old 03-02-2004, 09:08 PM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
Yep, me, among others.
All that, a bag of chips, and more.
Powershot 2000.
Approximately 80 more hp at the rear wheels. They're supposed to give an increase in mileage as well, but first, I'll have to learn to keep my foot out of it. I haven't seen an increase in mpg, it's the same as before, but I get where I'm going sooner.
I'd recommend two, but I don't know how you'd plumb them both in.
They're great, if used carefully. Used carelessly, they can destroy your engine. There are ways to safeguard against damage though. If you're serious about looking into it, I'd be glad to help you get started on the right foot.
Scott.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #3 (permalink)
Old 03-02-2004, 09:43 PM
I have a BullDog chip and a AFE air filter and a 4" exhaust on the truck now and I'm looking for better fuel milage....
What do you think??
Also where do you live ???State??
Thanks Joe
__________________
2001 F-250 Crewcab 7.3 Auto 4X4.
Add on's 6637 air filter mod, Full 4" exhaust and a Bull Dog chip set at 65 hp.
TIRE SMOKIN, NOS PURGIN AND TURBO'S SCREAMING THAT IS PMRA DRAG RACING.
  #4 (permalink)
Old 03-02-2004, 10:56 PM
WeWeld WeWeld is offline
WeWeld is starting off with a positive reputation.
I have an old power shot system that I improved upon. I can spray up to 3 nozzles at once.
1 is for economy
2 is for towing
All 3 are for smoking anything.
My mileage goes up about 2mpg if I can keep my foot out of it.
I've been running it for over 5 years and over 150K it's a lot of fun but you need to be careful if you have powder metal rods.
I live in Ca.
GENE
__________________
99 F450 CC, AT, XLT LB
List Mod's in Gallery
Builder and Driver of Stroked Lightning 11.519 @ 119.26 mph
CoBuilder of De Ranged
  #5 (permalink)
Old 03-03-2004, 03:29 AM
Quadzilla's Avatar
As WeWeld stated, he gets a 2mpg increase if he keeps his foot out of it. I guess he's just got more self-discipline than I do. He's also got one of the original Powershot systems, if his is 5 years old. The newer ones, (mine is only one year old), have been detuned to prevent damage to the engine, but in so doing, they've reduced the amount that the system can flow. I've modified mine to maximize flow, but that's just the kind of guy I am.
If you were to get a system, and could control your self, you'd likely see an improvement, especially when towing.
I live in the Seattle area.
__________________
  #6 (permalink)
Old 03-03-2004, 08:09 AM
JMorton JMorton is offline
JMorton is starting off with a positive reputation.
I should be getting my system today!!! Quad has me all jazzed up to get it installed and going. I'm going with the Bully Dog system just because I'm getting a heck of a deal on a used system, otherwise I'd go with the Powershot 2000 becuase of all the good things I've heard about it. I can't wait!!! Thanks a lot Quad for the previous advice!!
__________________
97 Crewcab PSD, Wildman chip, DIY-injectors stage 1's, SD Intercooler, 3" DP, 4" straight pipe, DIY exhaust brake, Tymar, Shimmed FPR, Bully Dog propane, Diesel Turbo Lifesaver, Autometer Gauges, B&W hitch, Timbren SES.
  #7 (permalink)
Old 03-03-2004, 04:20 PM
Quadzilla's Avatar
No problem. Let me know if anything else comes up I can help you with.
Scott.
__________________
  #8 (permalink)
Old 03-03-2004, 08:14 PM
stormyrider stormyrider is offline
stormyrider is gaining momentum as a positive member of FTE.
propane injection
My son has modified his service truck to propane boost. He is in the Army over in Iraq and it is a 1 1/2 ton. He removed the cold weather start ether injection setup and put the propane in there with a switch operated valve. He said only problem was if you stayed at full throttle too long the turbo exhaust would get really hot. He installed it for when you need to change locations in a hurry and he said you wouldn't believe the acceleration you get with it.
  #9 (permalink)
Old 03-03-2004, 08:45 PM
Quadzilla's Avatar
Actually, making power with propane is a little cooer than doing it with diesel fuel alone. For example, if a stock truck makes 190 rwhp, doing that with a mixture of propane and diesel will be cooler than doing it with straight diesel. However, with propane, you're capable of making a lot more hp, so doing that makes the truck run hotter. If I'm blasting up the 12% test hill, my speedo, tach, boost gauge, and pyro swing from left to right in unison, like the Rockettes.
__________________
  #10 (permalink)
Old 03-03-2004, 10:27 PM
MTMike MTMike is offline
MTMike is starting off with a positive reputation.
Quote:
Is that James Street?
mike
__________________
2000 F350, PSD, 4x4, Lariat, SC, LWB, Line-X, ISSPro Pillar Gauges, Diablo Predator, MBRP 4" SS Exhaust, 6637, Relayed lighting harness with "Euro lights", SS nerfs, Billet Grill, clear parking lamps, Warn hubs.
  #11 (permalink)
Old 03-04-2004, 04:16 AM
Quadzilla's Avatar
So, you apparently know a little about Kent.... Actually, no, it's a new road they've put in about a year ago that runs up the East Hill. It's 277th Street, and cuts up the hill directly beside the drive-in theater on Auburn Way. It dumps you out on Kent-Kangley at 116th, if you're familar with that area.
__________________
  #12 (permalink)
Old 03-04-2004, 09:41 AM
I lived at the top of Kent Kangley for a couple yrs in the late '70s and occasionally worked at the space center. Haven't tried that new road yet. Sounds like fun :-)
Currently, I'm doing some contract work in redmond.
mike
__________________
  #13 (permalink)
Old 03-04-2004, 05:22 PM
Quadzilla's Avatar
Mike- If you decide to run the hill, here's the deal: From Auburn Way North, head up the hill. At the base of the hill, there's a 50mph Speed Limit sign, (Yeah, right!) Hit that sign at 60mph in OD, and bury your foot. See how fast you're going when you hit the top of the hill. I consistently hit 80mph.
I generally have to pick the Camry's out of my grill when I get home, though.
__________________
  #14 (permalink)
Old 03-06-2004, 07:55 PM
Well, how could anyone turn down a chance like this?
Hit the bottom of the hill at about 55 (traffic). Managed 70 by mid way up but couldn't get anymore - just held 70. BTW, there was a Camry next to me :-)
Your mods must be doing something good!
mike
__________________
  #15 (permalink)
Old 03-07-2004, 05:07 PM
powerstrokin97 powerstrokin97 is offline
powerstrokin97 is starting off with a positive reputation.
Alrighty, thought i'd throw a curveball in there for you guys to think about. This last fall, a buddy that pulls with an 02' duramax installed a homemade propane setup. And it was probably the last pull we went to last year when he finally got it installed. me n' him were talking before the pull and wondered what effect mapp gas would have (50% acetelyne/ 50% propane)... and WOW it made that little chevy scream. The only detrimental attribue the the mapp however, was that it made the egts jump.
__________________
99' F-350 ex. cab 4x4: 7.3l Powerstroke, Auto., StageII injectors, 5" exhaust, K&N Air intake, tuned 6pos TS Performance chip.
08' F-350 CC 4x4: 6.4l Powerstroke, Auto., Afe Stage2 intake, DPF/CAT delete, RCD tuned sct livewire.
Tags
bulldog, diy, duramax, homemade, injection, pictures, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
