I searched and found iffy info, stuck on defrost
as youre sure of by now im having the typical air stuck blowing on defrost problem. I tested the electrical plug and it was putting power to the pump but pulled the line off the pump and felt nothing. I replaced the pump because the switch still works, it goes to off, max air air con and so on. anyways replaced the pump and still nothing, yes its hooked up just as the old one came off.
Is there anything I may have done wrong?
Any help is greatly appreciated.
-Webb
-Webb
When you turn the key from off to the on position. do not start the truck. listen for the pump to start running. Pop the hood if you need to and walk over to the pass. fender. You'll should usually hear the pump run for about 30 seconds or so and then shut off if it's working properly. If it is constantly running then you have a leak somewhere.
If it does shut off, then I would suspect either a pinched line or a stuck valve
tried that and didnt hear anything. So I tested the connector again and got the same number, a friend told me what the number actually meant... It wasnt getting any juice. SO I checked the fuses and BAM blown. Replaced the fuse and shes back to normal. Also tested the old pump to make sure it wasnt just the fuse all along and the old one still didnt work. From what I hear when the pump starts going bad it sucks alot of current and blows the fuse.
Hope this helps someone in the future.
