Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-01-2004, 08:59 PM
TimmyAbrams is starting off with a positive reputation.
Angry A4LD and I broke a lug nut stud.
I've got two problems on the ole B2 (88, 2.9, 4x2, auto A4LD)
My transmission continues to slip in second to third and third to fourth. I am going to adjust the band, but I just wanted to make sure that the rear bolt is the intermediate adjustement. Is it supposed to be torqued down to 120 inch-pounds and then backed off 2.5 turns or three turns? I've heard it a couple of different ways, but I now ask for help from the professionals.
Next, my passenger side front brake locked up today. I'm flushing the brake system and am either going to replace or rebuild the caliper. When I was taking the wheel off, one of the lug nuts froze on the the stud. I got mad at it and turned all I could. Naturally, the stud broke on the inside of the rotor. How hard is it to replace a stud and what is the ball-park procedure. My Haynes guide says nothing about this.
The ole B2 sits and waits in the driveway until payday for parts.
I'm going to have to get a second job to pay for her new stuff.
Thanks yall.
Tim
__________________
Gone: 1993 Bronco EB, 5.8, E40D, 160k, we miss you!
New (to me): 1995 Bronco XLT, 5.0, new Jasper E40D, 157k, a work in progress
1978 MG Midget, 1.5, 4-Speed, 99k
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-01-2004, 09:00 PM
Oh yeah, I replaced the fluid and filter in the tranny. The fluid smelled burned.
__________________
  #3 (permalink)
Old 03-04-2004, 07:03 PM
jcurrie is starting off with a positive reputation.
It's very easy to remove the broken stud. Just take a center punch and put it in the center of the broken stud. Hit with hammer until you drive it out the back side of the hub.
__________________
jcurrie
1999 Explorer Sport
1984 Bronco II
1979 MarkTwain
1979 Skeeter
  #4 (permalink)
Old 03-05-2004, 09:45 AM
shifty is starting off with a positive reputation.
you may have to remove the hub to get the wheel stud back in, as for the trans, sounds like its about to die.
  #5 (permalink)
Old 03-07-2004, 11:45 AM
Thanks Shifty and Jcurrie
Didn't realize how easy it was to do the lug nut. The tranny now only slips once from second to third.
Does anybody know about band adjustment on the A4LD?
__________________
  #6 (permalink)
Old 12-09-2007, 10:43 PM
LTBeck41 is starting off with a positive reputation.
Question Broken wheel stud replacement
Back to the stud replacement...can you replace front and rear studs without taking off the hub? Teenager/prior owner snapped off a full set of locking nuts so I have to replace one stud per wheel. Sure would hate to spend all Christmas break redoing four hubs since the mechanic in me would do a full hub guts service while I had the bearings in hand.
  #7 (permalink)
Old 12-10-2007, 02:57 PM
projectnitemare is starting off with a positive reputation.
For the stud question. For the fronts you need to pull the rotor and pound them out. Depending on the stud legnth for the rear you can replace them without pulling the axle. Pound them out and slide the new ones in.
If the trans fluid smells and looks burnt then the trans is on its way out. I've never owned or worked on an A4LD. It's pretty much common knowledge that they die pretty easily though.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
