Injectors
Old 02-29-2004, 10:08 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Injectors
Anyone know if the injector resistance on a 95 302 is high or low? Low is like 2-5 ohms and high is 12-16...anyone know?
Old 03-01-2004, 07:03 AM
StrangeRanger's Avatar
StrangeRanger
StrangeRanger is offline
High, around 15 ohms. It's easy enough to measure just probe both contacts with your multi-meter
Old 03-01-2004, 08:49 AM
MustangGT221
So any 5.0 injector that is high resistance is ok to put in my truck?
Old 03-01-2004, 09:15 AM
frederic's Avatar
frederic
frederic is offline
They are all high impedance (15-16ohms) as far as I know, however make sure its the same injector, in that the colors and markings are the same.
Having 7 injectors of one size, and 1 injector a hair larger or smaller in flow rating, will really confuse your ECM. I know, because I did just that on a different project and wasted a lot of time trying to figure it out.
Of course i should have applied the "last in, first to check" theory...
Old 03-01-2004, 09:52 AM
MustangGT221
Well I need 24# injectors and am trying to find a set on ebay to get a deal..all I see are mustang injectors so I'm hoping they'll be fine.
Old 03-01-2004, 11:33 AM
StrangeRanger
They'll work fine.
Old 03-01-2004, 12:42 PM
frederic's Avatar
frederic
frederic is offline
If they are sized as you desire, being 24lbs, you're fine.
Injectors are injectors, for the most part they all fit different engines, even the connectors.
Old 03-01-2004, 06:37 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
I think the only time you will run into low impedance injectors are in the very large sizes. Like 48lb/hr and up or something, I can't remember, but you shouldn't have any problems with 24's.
Blind Driver
01-07-2013 10:46 PM
BigAlsPSD
09-29-2011 09:11 AM
FI460
01-12-2011 06:48 AM
KevinC.
07-28-2009 08:46 AM
reinerguy
07-05-2004 08:11 AM
Quick Reply: Injectors
