How well did you clean the carburator? It sounds like my vehicles when they're not getting enough fuel into the cylinders.
After I dipped my carb parts in cleaner I decided to see where all the little holes flowed to and in the process discovered that the dip did not clean all the holes enough, mainly the needles (or whatever they're callled). So using a tooth pick and my mou...err.. some air and water, I got all the the grunge out of them. So you may want to take out your jets and check to make sure that the fuel can flow through them. it's been along time, but I beleive the needles were screwed into the top of the jets, in fact they may be the jets but I don't know much about carbs.
Good luck!
