460 ci Torque and HP rating - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-23-2001, 05:03 PM
kenvs kenvs is offline
kenvs is starting off with a positive reputation.
1995 F250 with stock 460. What's the torque and HP?
Old 10-23-2001, 06:34 PM
DeGideo DeGideo is offline
DeGideo is starting off with a positive reputation.
The rating was 245 horsepower@4,000rpm & 395 lbs.-ft of torque@2,400rpm with the 5-speed manual.With an E4OD automatic, the horsepower rating was the same,but the torque rating was 400 lbs.-ft.@2,200rpm.1995 Superduty(F-450)&stripped chassis(RV)trucks got a 255 horsepower 460,with 405 lbs.-ft. of torque@2,400rpm.Horsepower peak was at 4,000rpm,just like the 245hp version.The ratings for the 255hp version stayed unchanged for both manual&automatic equipped trucks.Hope this helps.
Old 10-24-2001, 09:01 AM
odinmurphy odinmurphy is offline
odinmurphy is starting off with a positive reputation.
Stock 460 vs Stock 351W for low end torque and hp? eriklane Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 08-06-2015 09:35 PM
what is hp and torque for 85 460ci? GTBksRule Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 11-20-2005 08:02 PM
stock power ratings KeithMS Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 10-31-2005 12:48 AM
hp and torque numbers? rustyolred27 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 10-30-2004 07:36 PM
351c specs scottjohn Performance & General Engine Building 2 09-22-2002 01:06 AM
Tags
1995, 460, ci, engine, f250, ford, horse, horspower, hp, power, rating, ratings, specs, stock, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
