Vacuum pump pulley removal/installation - Ford Truck Enthusiasts Forums
Old 02-29-2004, 02:57 PM
ctann ctann is offline
ctann is starting off with a positive reputation.
Hi All,
Just ordered a new Vacuum pump to replace the previous one which seized on my 1990 F250/7.3 IDI. ($102 from Kragens). from the pictures on their website, it looks like the new one comes without pulley. I took a look at my old one, but can't see exactly how to remove the pulley. Does it need a puller to remove, and to be pressed onto the new pump?
There is a threaded hole in the front of the shaft on the old pump - I'm sure that must be something to do with removing/replacing the pulley, but I'm not sure what...
Thanks,
Chris.
Old 02-29-2004, 09:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
That bolt hole is for the reinstall after you get it off.
They make a puller that goes in the groove around the hub to pull it off.
Some of the pullers on the market will not fit into the dish shaped pulley with out a few trips to the bench grinder.
But then you will have one that works first time, the next time.
Old 03-01-2004, 01:22 PM
Hi,
Thanks. I went to pick up the new pump, and they told me that their puller wouldn't work - I grabbed one off the shelf there, and it worked fine.
To install the pulley on the new pump, I needed a 1/2" Course
thread bolt (strange that its 1/2" when the rest of the bolts
on the unit are metric...) and a couple of washers. The washers
need to be pretty tough - just clamp the pulley in a vice, insert
the bolt through the washers, through the pulley, and then into
the threaded hole in the pump shaft. Slowly cranking away on the bolt with a wrench, until the pulley lip is flush with the shaft...
Chris.
Old 03-02-2004, 10:47 AM
Birken Vogt Birken Vogt is offline
Birken Vogt is starting off with a positive reputation.
When I do a vacuum pump, to remove the pulley I just use the old "sockets in the vise" trick to push the whole crank shaft of the pump out the back and out of the pulley at the same time. Destroys the pump, but it was no good anyway. Then putting the pulley on the new one is a simple matter with a bolt and impact wrench.
Birken
power steering pulley installation tommyblack 2004 - 2008 F150 2 01-08-2015 01:02 PM
Vacuum pump pulley Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 11 03-10-2012 09:53 PM
Power steering pump pulley bent?.... '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-11-2011 03:51 PM
vacuum pulley? stoney720 1994.5 - 1997 7.3L Power Stroke Diesel 1 06-10-2009 04:33 AM
239 crank pulley HT32BSX115 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 21 06-08-2005 05:43 PM
Tags
2003, 73l, diesel, ford, idi, installation, puller, pulley, pump, removal, remove, replace, replacing, siezed, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
