1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Clutch Problem
Old 10-15-2001, 10:33 AM
Ric_K's Avatar
Ric_K
Ric_K is offline
F250 Clutch Problem
My F250 351ci 4*4 Hydraulic cluch uses fluid. I can not see any leaks. When the fluid reservoir drops, once or twice a week, the petal stays down. It's worst in cold climate. When full of fluid the clutch works fine.
Any suggestions???
Old 10-15-2001, 05:16 PM
powerstroker250's Avatar
powerstroker250
powerstroker250 is offline
F250 Clutch Problem
Maybe the slave cylinder is leaking inside the bellhousing. You MUST have a leak somewhere.
Les
Old 10-18-2001, 07:48 PM
mikeinsequim's Avatar
mikeinsequim
mikeinsequim is offline
F250 Clutch Problem
Old 10-25-2001, 04:01 PM
Oldchap's Avatar
Oldchap
Oldchap is offline
F250 Clutch Problem
You don't mention the year, but I had a 94 F-250 with the 5 speed manual which went thru 2 slave cylinders (which also serve as the clutch throughout bearing) in 100,000 miles due to leaking. The leaking fluid ends up in the clutch housing. It's a real pain in the rear to change, since the transmission's input shaft passes thru it, requiring the transfer case and transmission to be pulled to get the new one in! The symptom is that the clutch engages closer and closer to the floor, until the clutch barely disengages at all.
John C
Old 10-26-2001, 10:44 AM
Ric_K's Avatar
Ric_K
Ric_K is offline
F250 Clutch Problem
That's it. My F250 is a 95 model. What did it take to fix the problem. Is this a Ford design problem or is it just you and me?
Old 10-26-2001, 12:11 PM
Oldchap's Avatar
Oldchap
Oldchap is offline
F250 Clutch Problem
Unfortunately, you have to pull the transmission and transfer cases back more than a couple inches from the clutch housing and replace the throwout bearing. Depending on your mileage and driving habits, this might be the time to replace the clutch and possibly the pressure plate as well. The first time it happened, I was short on time, and had to let Ford do it. They didn't recognize the problem (I guess I got a dumb mechanic) and he replaced the master cylinder, clutch and pressure plate as well. No amount of argueing would get me my truck back for less than $1500! Oh well.
The second time it happened, I retired the truck to part time duty as a local work truck at a summer camp, where it probably gets less than 1000 miles a year. Never fixed it, I figured I'd wait and see how bad it gets. So now, it engages about 1/2" off the floor, but otherwise still works well. Hasn't seemed to have gotten any worse in the last year or so. I don't understand that. I would have thought I'd eventually be starting the truck in gear!
If you can find an aftermarket throwout bearing that is a bunch more heavy duty than Ford's original, let me know! I really hesitate to put the same problem back into the rig by using another of Ford's gem.
1995F250351
12-21-2015 09:12 PM
dougbrown
11-16-2012 04:59 PM
iworkalone
11-13-2011 10:58 PM
79F250inline
03-27-2011 07:19 PM
redbug
11-25-2003 07:29 PM
Quick Reply: F250 Clutch Problem
