04 Explorer Head Unit Removal
Old 02-29-2004, 12:52 AM
viper48220's Avatar
viper48220
viper48220 is offline
I have an 04 explorer with the 6 disc in dash HU. I am having problems with the RDS on my stereo, and I want to check the antenna connection before I take it to the dealer. Does anyone know how to remove the HU? It doesn't have the holes along the edges for a removal tool. I think I need to remove the trim around the stereo, but I'm not sure how and don't want to damage it. Any advice?
-Steve
Old 03-01-2004, 11:42 AM
srallen99's Avatar
srallen99
srallen99 is offline
Re: 04 Explorer Head Unit Removal
What type of problems are you having with the RDS? In general, if you are getting good FM reception then the antenna wire is connected. There isn't a separete antennal for RDS, so either audio and RDS should both be good or bad. Keep in mind that depending on where you live, the number of stations that USE RDS could be fairly limited...
Old 03-01-2004, 11:47 AM
viper48220's Avatar
viper48220
A few of the stations in my area broadcast the song name, artist, etc via RDS. On my car, the characters get scrambled quite a bit, and also it skips words. Some of the time, it won't even show the RDS data. I suspected it was because I was too far from the transmitter, but I've been in 3 other cars with RDS in my area, and they all worked flawlessly.
-Steve
Old 03-01-2004, 11:57 AM
srallen99's Avatar
srallen99
I would take it to the dealer and have them replace the radio -- sounds like it is screwed up to me. I don't think a loose antenna cable would cause this.
ocdmachine
08-13-2013 11:45 AM
cstamper
06-25-2006 06:13 PM
8iron
04-17-2005 06:25 PM
JonC
09-08-2004 08:27 PM
dtustin
2004 - 2008 F150
08-08-2004 09:39 PM
Quick Reply: 04 Explorer Head Unit Removal
