Drillin sheetmetal
Drillin sheetmetal
Now here's a task I've never mastered. Clean large holes in lightweight sheetmetal. I'm not talking about a 1/4 hole. I was punching a 3/4 hole in the glovebox sheetmetal radio mount, for a rocker switch. You know, the one I put the matching fabric on and was so proud of. Bit bound up as it was going through and just mangled it today. I can't afford 15 quality drill bits from 1/2 to 3/4. Know any tricks?
do they make any hole saw sheetmetal bits that size?
I used one to put gauges on my 74 thing, but those were 2 + inches.
*zillionth edit* (took me forever to find a working link)
qmax punch
qmax punch
Have you seen those Multi-bits?
Its one of those "cone" shaped drill bits that step up to different diameters. Each diameter drills the pilot hole for the next.
They are kind of pricey though.
Another trick is to sandwich the sheetmetal between two pieces of wood, clamp it together, and then drill through all 3.
Holesaw bits work pretty well if you are starting fresh so the center bit can be precisely located.
I can see how the wood sandwich should work if the metal is flat and you can get C- clamps in there, though I'm not sure how to precisely locate the hole center with a bunch of wood in the way.
I have been looking at those multi-bits. Never used one but it would be worth the high price as long as I don't stuff it in a frame hole and wear it out in a day.
Dewayne, look for the "Uni-bit". They start at about $24 each but are a good investment. I bought my first one to install blue-dots in plastic taillights. It works equally as well on sheetmetal. You will wonder how you got along without one.
For you, I might be able to loan you mine. Just pay shipping both ways. Or take the 2 hour drive to the Truck Farm!
truckfarmer has the answer. The uni-bit has saved me more that once. They make one that starts at one eighth inch and goes up to one half inch at one thirtysecond increments. They also have one that starts at around one forth and goes to almost an inch at eighth inch increments. Good luck.
Gear Up
Gear Up
Originally posted by Gear Up
fenders, there isn't any upholstery on this sheetmetal is there? Could catch on the bit as well. I've had that happen as well.
Gear Up
Gear Up
Well of course it'ds upholstered. It may be trashed before I am done, if it isn't already. The fabric is not a big deal. The hours I spent bending a perfectly fitting false glovebox bottom kinda stinks, but at least I have a pattern this time.
Looking forward to posting some PICs. I got the last details of the interior, wiring, seat belts and audio coming to a conclusion finally.
Uni-bits are great but a bit pricey unless you use them all the time then I think they pay for themselves in reduced aggravation.
Check out your local electric supply house...sometimes you can borrow the greenlee punch sets for a deposit - like the auto parts stores loan gear pullers and such. These things were made for punching holes in sheet metal and you can get dies to punch square holes as well - sometimes very handy and much easier than drilling and getting the files out.
OilLeaks
OilLeaks
