Gas...does it make a difference?
Old 02-28-2004, 12:03 PM
Inda Bonda's Avatar
Inda Bonda
Inda Bonda is offline
Here, I believe, the highest octane is 93. Will my truck see much difference between 87 octane compare to 93? I here that some say there's no difference and some say so.
Old 02-28-2004, 12:09 PM
Drizzt's Avatar
Drizzt
Drizzt is offline
you won't notice any difference on a stock engine. the only difference with fuel octane ratings is that the higher rating takes longer to burn. this is so that in higher compression engines you don't get pre-ignition (detonation, pinging) under load because the fuel is lighting on fire before the sprak plug fires. when this happens the two flame fronts meet and cause a pinging noise which can mean death to your engine
Old 02-28-2004, 06:44 PM
MrBean1130's Avatar
MrBean1130
MrBean1130 is offline
so does that mean it is bad for a stock engine to use 93 octane?
Old 02-28-2004, 07:06 PM
BrianA's Avatar
BrianA
BrianA is offline
Using 93 ocatne will not harm your engine. It won't necessarily help it either. If you are not experiencing pre-ignition or detonation (these are commonly called "pinging" or "knocking"), you will not realize any noticeable benefit by moving up in ocatne ratings.
I suggest you visit http://www.chevron.com/prodserv/fuel.../supreme.shtml
and http://www.shelloil.com/ and find the info on gas and octane.
These sites give good info on octane and fuel requirements.
Old 02-29-2004, 12:26 PM
Drizzt's Avatar
Drizzt
Drizzt is offline
well said brian
Old 03-01-2004, 09:24 AM
true4.2's Avatar
true4.2
true4.2 is offline
If you get a chip programmed for 93 octane gas, you will notice a big difference. But, just stock, you'll notice nothing.
Old 03-01-2004, 03:08 PM
Busa01's Avatar
Busa01
Busa01 is offline
I believe that detonation (the actual sound) is caused from the fuel igniting prior to your pistons reaching top dead center, therefore causing your piston to jerk or bang as it hits TDC and begins its downward revolution. The only advantage to the higher octane fuels is that they contain additional additives designed to clean your fuel system. Save your money though, on a stock motor. I believe your manual says to run a minumum octane rating of 87. Your trucks fuel system is engineered and designed to run at this octane level. If you desire to run 93 and are looking for a boost at that level, than do as Joe says and drop a 93 tuned chip in your truck, the difference is night and day.
Tom
p.s. Joe, looking at your times, we would have had a very competative race at Houston. But, unfortunately, you would've beat me
Old 03-01-2004, 04:56 PM
Drizzt's Avatar
Drizzt
Drizzt is offline
the pining sound is actually from the two flamefronts meeting and slapping the piston...
Old 03-02-2004, 07:13 AM
Busa01's Avatar
Busa01
Busa01 is offline
I think that's kind of humiliating and degrading to the pistons, don't you? Is it a straight up open fisted slap, or is it that french style where the glove is taken off and used as a humiliating slapping device???? (most embarassing)
Tom
Old 03-02-2004, 08:16 AM
Inda Bonda's Avatar
Inda Bonda
I don't think it matters...the pistons just get pimp slap by to flamers.
I hope that I don't get pimp slapped by two flamers, or even one.
Old 03-02-2004, 08:25 AM
Busa01's Avatar
Busa01
Busa01 is offline
Old 03-02-2004, 08:26 AM
Busa01's Avatar
Busa01
Busa01 is offline
inda,
change your last [img] for your picture, to [/img] and then your picture will display correctly.
Old 03-02-2004, 08:39 AM
Inda Bonda's Avatar
Inda Bonda
true, what chip are you talking about? The Diablo chip?
BTW: how long does it take motortrend to ship something. I ordered the MAC Friday after hours and haven't heard from them since.
Old 03-02-2004, 08:56 AM
Busa01's Avatar
Busa01
Busa01 is offline
Motor trend?? You mean Motorhaven right?
Here's your picture.
Old 03-02-2004, 08:57 AM
Busa01's Avatar
Busa01
Busa01 is offline
there
