homemade suspension lift - Ford Truck Enthusiasts Forums
Old 02-27-2004, 09:25 PM
plowboy2155 plowboy2155 is offline
plowboy2155 is starting off with a positive reputation.
I was just thinking of maybe a cheaper way to give my '94 F-150 a lift. I was looking at 6 inches and was wondering if anyone has ever tried to lift a truck by relocating the spring perches on the frame by making a bracket to weld or bolt underneath the frame. If the brackets were made strong enough, I think it would work I just want some other opinions on the matter. I want to lift enough to run 35's
Old 02-27-2004, 09:46 PM
ivanribic ivanribic is offline
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
Look at Pro's spring perches in his gallery. I think that's exactly what he did. Springs are pretty much stock. Double check your measurements but I don't think you'll need to lift a full 6" to fit 35's.
Also, do a search on the offroad forum for "shackle flip". You could probably acheive plenty of lift in the rear to fit 35's by doing this and it's less hassle than relocating your front perches.
Old 02-27-2004, 09:50 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
yea man, check out my gallery...i did the shackle flip and I love it. although I am actually gonna put an add a leaf b/c it is almost too soft and to give me another inch or so!
Ho built his front springs but doesn't like it and he is gonna just go buy a 4" lift for the front....ironic huh?
-Jason-
Old 02-27-2004, 10:16 PM
I'm still debating on buying a set of springs for the front but the rear will definitely be a Homer. I know I'm flipping the shackle, will have to wait until tires are here to figure out if I need to move my front hanger down too.
Jason, is it your rear springs that are soft or the shacke flip?
Old 02-27-2004, 11:37 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Hold on guys....94 F150 is the key here, the problem with moving down the spring perches is that you still need to drop the pivot brackets in the middle of the axle. Leaf springs this will work but not with coils.
Old 02-27-2004, 11:38 PM
it's the springs...they are higher than they are used to , plus i have been flexing a lot more and stretching them out doesn't help any!
-Jason-
Old 02-28-2004, 12:13 AM
thanks for the help guys. I think I have decided on the shackle flip for the rear. That still leaves me wondering about the front. What would be the cheapest way to lift the TTB. I know i need to drop the center and the radius arm brackets and add longer springs and shocks. i know i'll also need a new pitman arm and probably some camber bushings. am i leaving anything out?
Old 02-28-2004, 12:33 AM
moose94's Avatar
moose94 moose94 is offline
moose94 is new and has a neutral reputation at this point.
here's what you should do man. Look I know you want the cheapest way to get those tires on and I feel the same way, but there's a point where you need to tell yourself - what do I really want in this build.
plowboy2155 - Do you want something that's kinda thrown together and may cause damage to other parts later? Or would you rather pay the money, do it right and take a step back and look at your truck.
Look man, I want a 6" lift too but it's expensive cause I live in canada.
Now you can get 4-6" lifts for under $500. Which includes everything except brake lines and you'll have the peace of mind in knowing that everything is covered and you didn't leave anything out.
If you do the math and add up everything you are going to need.... it works out to be just the same as buying the kit.
For my lift I have an add-a-leaf in the rear and for the front I plan on buying a leveling kit (well springs only). This will give me enough space for my 33's. I have a set of 35's (BFG), but I don't know how I'm gonna make those babies fit.
So I would reccomend doing the kit as far as the custom build. Um I believe Rough Country or Tuff Country (stupid names for companies) makes lifts for $499. Also check www.natltire.com for suspension specials they have our trucks on special.
Alright that's enough for me, hope everything goes well for you and if you do decide to do the custom job let us know how it went k? Good luck.
Old 02-28-2004, 01:17 AM
Quote:
Don't know where I left my head when I read that part. Try this search link: http://ford-trucks.com/forums/search...der=descending
There was a post about a week ago that is listed in there in which all different brands of lift for TTB are discussed, prices and all. Somewhere down the line there's a thread on what all needs to be done if you're going to built it yourself but for the work it would take you're better off buying a kit up front.
Old 02-28-2004, 01:35 AM
hoxiii's Avatar
hoxiii hoxiii is offline
hoxiii is gaining momentum as a positive member of FTE.
If you're pretty good at fab work and welding you can do a 4" lift for the cost of a set of 4" springs and some 3/16 plate steel. You actually mount the TTB arm in a jig, cut the pivot eye off of the arm, move it vertically 4" on the jig, and fill in the gaps with the 3/16 plate. It's also a stronger setup than using drop brackets since it won't add any more leverage against the frame.
Justin
Old 02-28-2004, 02:46 AM
92 f150300six 92 f150300six is offline
92 f150300six is starting off with a positive reputation.
here aybe by the end of this weekend ill have my 6 inch ttb brackets off my truck(going soild) i would be willing to sell. give me a email and will talk if u want them
Old 02-28-2004, 04:08 PM
Nickiboy Nickiboy is offline
Nickiboy is starting off with a positive reputation.
Hey Fishmann................ where did you get your flip brackets from... I think I'd be very interested in doing that lift.
Old 02-29-2004, 11:46 PM
Quote:
http://www.sky-manufacturing.com/
-Jason-
79' F150 4in lift, radius arm questions doug79 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-07-2013 05:46 PM
Super duty on a two post lift? imgoin 1999 to 2016 Super Duty 2 09-23-2012 01:56 PM
Lift Question(s)... Baja16 1999 to 2016 Super Duty 12 09-16-2011 10:24 PM
air bags with 6" lift frdf250 1999 - 2003 7.3L Power Stroke Diesel 30 02-22-2011 08:18 PM
Rear Sag 3KIDDAD Excursion - King of SUVs 13 02-15-2007 06:23 PM
Tags
airbag, f150, f350, ford, home, homemade, homemadeliftfortrucks, kits, lift, lifts, link, make, road, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
