ah its a ranger mix bread 94 mazda b3000 V6 3.0 manual trans 5sp 160... miles
94 mazda b3000 with 163... miles 3.0 v6 5sp manual trans X-Cab
hello im haveing sort of a problem my truck computer has been screwing up i belive becaus ive been haveing to pull battery cabbel off an put it back on for it to start dose any one know wut may be cussing this to happen ive changed my heater core an thout i might of gotten some water on it I DONT KNOW
i have the haynes repair manueal...
THANKS Brent
THANKS Brent
Black Beauty Factory Racing
well i put a msg already on here but dunno wut im doin haha so im puting another one. ok ive changed my heater core an thout i may have gotten water on the computer becaus my temp, battery and water gages were off an hard to start an my alltanator was charging! an battery was fully charged!so id thout to disconect the battery cable an put it back on an well thought that would do it but next morning i start her up an every things fine i go ride get back park try start her again an well same thing nothing but CLICK
Well hope ya know somthin that may help me THANKS Brent
Let's tackle one problem at a time.
Now when you turn the key to start the truck, all you get is one single click instead of the starter cranking the engine over?
Make absolutely sure that all the battery connections are properly cleaned and tightened.
This "one click" is not always a stuck starter.
Car repair Rule # 1...Is the battery good? (prove it).
Car repair rule # 2...Is the battery properly connected to the car? (check & clean all connections carefully).
Once that is done, you can move on to pulling codes etc, etc.
ok i have another question iv hollowed out my catalytic converter and put a duble chamber flow master one pipe factory style with you no the chrom tip for show. i put 27x8.50x14 mud brute that for hunting an a lil playing off road... im a big fan of trying to ceep my truck clean an up keep and runing good
OK im looking to gain a lil horse power
#1 should i bye the old two (catalytic converters) that come from the factory with the truck are or my hollowed out ones good? are any better solutions?
#2 im needing to (change my clutch) an i know that they say for your vehical you shouldnt worry about the price i dont know about where you from but $$ dosnt grow on trees in louisiana well any good clutchs hevey duty for pulling trailers off roading and all?
#3 an well also any kind of throttle ajustment are are any thing i can add are change for a more sensative gas pedal? maybe thats not posable i dont know thats why im asking
Thanks
Thanks
You lose very little power from a cat in good condition and they make high flow ones too. When you hollow out a cat you hurt the exhaust flow rather than helping it. The hot exhaust gases enter the empty cat and expand, as they expand they cool, hot gase flow better than cool gases. Also the pulses of exhaust tend to pull each other along and you lose the pulses in the empty cat.
nicenidaho
08-06-2015 01:34 PM
Rocketman55
10-11-2013 12:01 AM
prerunnerswag98
21
03-31-2012 09:01 AM
