Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 02-27-2004, 02:01 PM
awe911 awe911 is offline
Garage is empty, add now
awe911 is starting off with a positive reputation.
Ford f250 STRIPPED OIL PLUG CANT REMOVE HELLLLP
i just bought a f250 1987 and i went to change the oil but to my surprise the plug just spins both ways not tightening or loosening. it leaks about a dime size puddle per day but i would like some ideas before i start anything
  #2 (permalink)
Old 02-27-2004, 02:19 PM
sglaine sglaine is offline
Posting Legend
2000 Ford F-350
sglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant future
Cool Oil drain plug
I have owned Ford trucks for 23 years and I have had that problem more than onece. Is the oil pan in good shape? My 89 F150 300 six 4x4 oil pan went last fall. Now as far as the oil plug go,es try backing off with preshire . Then then talk to somebody about an oversize plug for that I have used it for years and no problem your are better off to have a mech. work on it for you so if it fails you can blame him. Good luck and do not worry because it is a common problem.
  #3 (permalink)
Old 02-27-2004, 02:22 PM
thank you will try the pressure and if that dont work then i will take it in...also the pan is in good shape.
  #4 (permalink)
Old 02-27-2004, 03:01 PM
Posting Legend
2000 Ford F-350
Oil plug
Well get it fixed fast I have seen them start to leak more & more as time went on. Good luck let me know how it works out.
88 F250 2wd 300 six 5spd pickup
99 F250 2wd 5.4 auto 8ft rack body dump 4.10
00 F350 4wd power stroke 6spd 9ft rack body 4.10
04 F250 4wd 5.4 6 spd pickup 3.73
  #5 (permalink)
Old 02-27-2004, 03:27 PM
well after i wrote last i went out and pulled that sucker out with some vicegrips no prob...will let drain and tommorrow i will be putting the new oversized plug in..keep ya posted.............
QUESTION?
i have a rod knocking,if i use 20w40 oil will that help quiet that knock since it is thicker?I am saving up the 2300$ to get a new engine but in the meantime will that work or what do u think?
  #6 (permalink)
Old 02-27-2004, 03:35 PM
Posting Legend
2000 Ford F-350
Cool Rod
Chance,s are if it knocking it is probbley bent keep the rpm dowm to min. What is the motor anyways? And how many miles are on the truck? I will call my mech and ask him the ? about the oil I get back to you in a few hours.
  #7 (permalink)
Old 02-27-2004, 03:40 PM
it is a v8 5.8 with 154000 milesi dont usually drive over 40 just to get to and from work right now....its such a perty truck i cant junk it i bought it for 800$ with a brand new edelbrock carb 4bbl new sensors new computer brain new starter 33' all terrains goodrich lots of tread a dana 60 the body is in awesome condition could use a little tlc around the tirewalls but as far as rust and scratches dents go NONE and the interior is in perty good shape so i think its worth the $ to fix it up.its a 1987 ford xlt lariat 3/4 quarter ton with 154k miles
  #8 (permalink)
Old 02-27-2004, 03:50 PM
85BigBlock's Avatar
85BigBlock 85BigBlock is offline
85BigBlock is starting off with a positive reputation.
If the oversized drain plug doesn't work, look into a piggy back plug(a small drain plug inside a larger one), but only as a last resort.
__________________
1985 F250 4x4 460 Auto
1994 T-bird 4.6 V-8
My family of fine Fords.
  #9 (permalink)
Old 02-27-2004, 03:54 PM
will do thanks for all replys when i need help this is always the first place i come to you guys are awesome stay cool
  #10 (permalink)
Old 02-27-2004, 03:58 PM
Posting Legend
2000 Ford F-350
Drain
If I where you I would think about a used low mileage motor sounds like that one is getting tired. I only got a 140,000 miles on my 5.8 motors but I work the snot out of then with my work. You can find low mileage motors that came out of wrecks cheap Give that some thought if you did that you will save more money than rebuilding this one.
  #11 (permalink)
Old 02-27-2004, 04:30 PM
thought about it but can you trust em?you think i can get one in.staying under 2300$
  #12 (permalink)
Old 02-27-2004, 05:32 PM
Posting Legend
2000 Ford F-350
Cool Oil Pan
Some salvage wards will let you hear the motor 1st before you buy. It go like this buyer beware. I am sure you can find something good ware you live. Ask around I bet you can find a great motor for around a $1000.00 or less check it it wont cost anything to check into it. Good Luck
Tags
1999, 2002, 250, bolt, engin, f250, f350, fell, ford, location, oil, oilplug, pan, plug, remove, stripped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
