Recipe for a 400hp/500lb-ft EFI 460... - Ford Truck Enthusiasts Forums
Old 02-26-2004, 10:23 PM
BigBlockF-250 BigBlockF-250 is offline
BigBlockF-250 is starting off with a positive reputation.
I have a factory re-man '88 EFI 460 in my truck right now. It only has about 10,000 miles on it. I would really like to get at least 400 hp and 500lb-ft out of it. Heres what I'm thinking so far:
Stage I:
K&N filter
1 3/4 to 3" tube full length headers
new hi-po cap/rotor and wires
jacobs miliage master computer controlled ignition
3" single exhaust, no cat, either straight or 40 series flows
Stage II:
Crane Powermax 272-2H grind cam
Crane roller rockers
JET chip
Thinner head gaskets to bump up compression ratio
BBK twin 70mm throttle body
So what do yall think? About how much power can I expect to get with the first and/or second setup? I will be using my truck for daily driving, towing, four wheeling and the occasional run at the drag strip. Thanks in advance for the help.
Matt
Old 02-27-2004, 05:34 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
You'll make less than 300 HP with either set-up. Also the 272-2 cam is going to require a 2,000 stall converter at least if your running an automatic and you'd probably want a 4.10 gear.
I ran my combo (see my signature) through my DD2000 software and only came up with around 265 HP. So I don't think 300 HP max is out of line with your Stage 2 setup.
By the way...the Crane catolog says that cam is for "Emissions Controlled Vehicles without Computer" and since you do run a computer you may have problems.
Deen
Old 02-27-2004, 09:33 AM
I was refering to fly wheel horse power. The factory motor has 280 hp, 410 lb-ft stock so you must be talking about rear wheel horse power? I have 3.55 gears in my truck, so my rwhp isn't going to be to great, but I want to get all I can. I will be keeping the 3.55 gears though, because I do drive the interstates alot and need to have half way decent milage. Oh and the truck does have a 5 speed manual tranny in it. I was hoping that the crane cam would work, but I better not try it because I really don't know what it would do with my computer. Are there any of the Crane Compucams that would fit my application? Thanks for all the help.
Old 02-27-2004, 03:28 PM
ExcellentRed ExcellentRed is offline
ExcellentRed is starting off with a positive reputation.
isnt the 460 more like 240 HP stock?
Old 02-27-2004, 11:52 PM
No, the fuel injected 460 is 280hp, 410lb-ft stock. The carb versions were probably arround 240hp stock, but I'm not sure.
Old 02-28-2004, 12:01 AM
doctorq's Avatar
doctorq doctorq is offline
doctorq is starting off with a positive reputation.
BigBlockF-250,
Regarding cams:
Check Comp Cams for this year/engine application. Better yet, read the thread on EFI cams which has been going on very recently in this very forum.
I will not make any horsepower guesstimates, but one thing you might want to add to your list is an adjustable fuel pressure regulator. I don't have one (yet!), but there's been a decent amount of talk in this forum as to a noticeable performance benefit by installing and tuning one.
Old 02-28-2004, 05:36 AM
Icicle's Avatar
Icicle Icicle is offline
Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.Icicle has a good reputation on FTE.
Hey deen, I noticed you said "with either" combo...I believe he listed it as stage one and two menaing he plans to do all of it in 2 stages, wasnt sure if you caught that or not......
Old 02-28-2004, 07:05 AM
Yes, I was talking rear-wheel HP. And yes, even with a total of both stages your RWHP will probably not exceed 300 HP.
BigBlockF-250,
That cam would be a real dog since your going to stay with the 3:55 gearing. Your going to need to stay around 260 to 265 advertized intake duration max. The truck is just too heavy and your gearing too conservative to make use of more cam duration. Just my $.02
Deen
P.S. The EFI heads are power killers...a small-block Ch** head almost flows as much on the exhaust side!
Old 02-28-2004, 06:23 PM
Thanks for all the good info guys. I am planing on doing this all in two stages (as my budget allows) and will hopefully be doing the stage 1 mods very soon. I hope that just those mods will wake it up a little for now, and when I get a little more money (and time) to spend on it I'll get into the more indepth stage 2 mods.
Old 03-07-2004, 09:24 AM
rankhankyellow rankhankyellow is offline
rankhankyellow is starting off with a positive reputation.
I run a Comp Cam 268 grind in my /02 EFI which is converted back to Carb. I would look at a computer version of this cam for your application, the power band is roughly 1500-5800rpm.
We have installed many of these cams on chevs & fords for everyday street driven vehicles with no negative feed back.
Old 03-09-2004, 08:40 PM
efi460 efi460 is offline
efi460 is starting off with a positive reputation.
my build
a9l efi with tweecer
stock intake with 61mmx2 tb
ported efi heads and milled 9/1 cr
crane 359341 hyd roller & roller rockers
zero deck block & kb 206 pistons
l&l headers
586 peak torque at 3000
459 peak hp at 5200
(engine analyzer 3.2)
Old 03-10-2004, 12:46 AM
Coogles Coogles is offline
Coogles is starting off with a positive reputation.
87-94 EFI 460 230 hp 395 torque.
95-97 EFI 460 245 hp 415 torque.
In 95, they changed the fuel rail and injectors a little, the pistons went up in compression significantly, and they had a whole lot of extra electrical nonsense.
Roller cam and L&L headers will give you the biggest bang.
If you really want some power, get a vortech supercharger. 3000 bucks and will add 5psi. It will take you from a stock 245 to about 350 hp. Just like that. L&L long tubes (legal injection) will probably take you up close to 400.
If you wana go illegal, hell you could do anything to increase power. Roller cam and heads would be my first step. Im not sure exactly how you get your computer calibrated for that, The vortech guys gave me a computer with the supercharger.
This truck is faster than a lightning.
Old 03-10-2004, 08:15 AM
Thanks for all the info. Unfortunatly, I wont be doing any of these mods anytime soon. My ATV took a turn for the worst last weekend while riding, so I'm going to be trading it on a new one soon. There went all the money for my truck mods...
Did any 351's come with an AOD from the factory? smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 07-01-2014 05:16 AM
Dana 60 Torque specs genscripter Clutch, Transmission, Differential, Axle & Transfer Case 2 11-16-2012 07:56 PM
day 3 (story/rant) meborder Explorer, Sport Trac, Mountaineer & Aviator 3 06-17-2012 05:30 PM
351w stroker motor wquestions 1990f150kid Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 03-22-2012 08:57 PM
Cam comparison on Desktop Dyno karlsd FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 11-07-2001 11:31 PM
Tags
400, 460, 500, build, efi, ford, heads, horsepower, hp, max, power, recipe, recipes, stock, tourqe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
