Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-26-2004, 10:49 PM
4wheeldr is starting off with a positive reputation.
Question 300 I-6 to a 390
I have a 1979 f-150 4x4 with a 300 I-6. I would like to switch it to a 390.
what problems am I going to encounter in this switch.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-26-2004, 10:59 PM
bob arrington is new and has a neutral reputation at this point.
if its an auto you will need a trans. also, if its a 4 speed you will need a flywheel/clutch/bellhousing, setup. a real good thing would be a doner truck or acsess to a junk yard . the motor towers/motor mounts need to be changed . its not a hard swap with a doner bob
  #3 (permalink)
Old 02-27-2004, 12:09 AM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
really its pretty easy, all the electrical is already there. like bob said, motor mounts, bellhousing, radiator and shroud.
  #4 (permalink)
Old 02-27-2004, 11:15 PM
thanks for the replies !
they have answered some of my questions
  #5 (permalink)
Old 02-28-2004, 11:58 AM
buzziscrazy2 is new and has a neutral reputation at this point.
If your gonna swap something , why an FE motor ?
  #6 (permalink)
Old 02-28-2004, 03:51 PM
3eggOmelet is starting off with a positive reputation.
actually that is a excellent question: why the FE motor? do you have one spare just laying around?
A better option would be a stroked smallblock for the same cubes. for example a 351w stroked to 393 would get you similar power without all the extra weight from the heavy FE motor.
__________________
'91 F-150 XLT 5.0
  #7 (permalink)
Old 02-28-2004, 07:07 PM
YES I DO, A 360 AND A 390.........You can have them, both run......
  #8 (permalink)
Old 02-29-2004, 02:38 AM
wow. wish you had a windsor laying around.
__________________
'91 F-150 XLT 5.0
  #9 (permalink)
Old 02-29-2004, 04:12 AM
MontanaFord is starting off with a positive reputation.
from what i've seen, there's nuttin wrong w/ the 390...overall, a good motor...mebbe ya'll know somethin i don't?
i'm considering building a rig, and as of yet, ain't real sure what motor i want to put in...what i'm looking at is a 3/4 ton 4x4, and i will have a 300-6 to play with and build up....i currently have an 84 half ton 4x4 w/ a 300, and spare 300 that i'm going to probably build as a stock motor to replace the wore out motor that is currently in the truck, and then turn around and put some money into the motor i pull, and build it up, just as something to "waste" money on, since i already have both motors available to me...i've considered a 351w, but don't have one readily available, and i think i want something with a little more power if i do choose to go with a v-8...i am partial, tho, to the inline six, because it is one helluva motor...i've owned two, and they have yet to let me down on anything i've actually needed them for...
MontanaFord
1984 F-150 4x4 300-6 4 spd 3:55 gears...tired old truck, but still a helluva rig, considering the abuse it sustains
__________________
1992 F-150: X-cab, short bed, 300-6, 5 spd manual, 114000 miles at time of purchase...gonna git shined up nice...
1982 Full-size Bronco: 300-6, 4 spd manual, 9" rear...gonna git some mods done soon...
Member: High Plains Drifters
  #10 (permalink)
Old 02-29-2004, 09:15 PM
nothing at all wrong with a 390. good motor, but in a lighter truck (f100, f150) less weight is better and the 390 is a heavier motor than a smallblock. plus in most half-ton trucks no special work is required to bolt up the smallblocks, but motor mount modification is required for the FE or bigblock engines.
in this case he has a I6 so he will probably have to do some motor mount work no matter which engine he decides to use.
__________________
'91 F-150 XLT 5.0
  #11 (permalink)
Old 03-02-2004, 08:52 AM
scamardo is starting off with a positive reputation.
Not true on the last post. No motor mount modification is necessary to swap from say a 300 6 to a FE. Unless you are going with power steering, then the drivers side perch will need to be swapped out. He has a 79 so the perches were the same from 65-79.
__________________
1965 F100 Stepside
390 CID
C6/PS/PB
  #12 (permalink)
Old 03-02-2004, 08:55 AM
Oh, I guess what you might have been saying and that I didn't pick up on (doh) was that the perches will have to be moved back to the next set of holes in the frame. Not a big deal though. no cutting required. If he swaps trannys, he will have to remove the frame crossmember, which is really fun. Get a air chisel to remove the rivets.
__________________
1965 F100 Stepside
390 CID
C6/PS/PB
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
