75W-140 synthetic differential lube?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-26-2001, 01:09 PM
powerstroker250 powerstroker250 is offline
powerstroker250 is starting off with a positive reputation.
Old 12-01-2001, 10:00 PM
fjlee fjlee is offline
fjlee is starting off with a positive reputation.
I have a 2001 F250 5.4 liter 4x4, NOT limited slip differentials.
The book says I need 75W-140 SYNTHETIC differential lube in the rear differential..
I can't find differential lube with those specs.
Where are you folks finding that product? What store?
Thank you...... Lee Carkenord
Old 12-01-2001, 11:35 PM
lrrpbn47 lrrpbn47 is offline
lrrpbn47 is starting off with a positive reputation.
I live in NY on Long Island. I saw the stuff at a place called PEPBOYS. If its a 2001 you souldn't have to worry about it. Are you doing heavy towing or loosing it then maybe. How many miles on your rig you like it? I have a 1988 F250 Extended & 8Ft bed. Love it
Old 12-02-2001, 12:04 AM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
I have also seen it at PepBoys. If you can't find it anywhere else, a dealership parts dept. should have it or at least be able to order it for you. Also, some of the "specialty" oil companies like Amsoil carry it.
Old 12-02-2001, 07:46 AM
RBC RBC is offline
RBC is starting off with a positive reputation.
For the amount of fluid you would need Ford sells in 1-qt containers so maybe just buy it there. The book for your truck will show you the amount you need also with the syn. lube it shows change interval at over 100,000 miles or more I believe. My truck pulls most the time so I change things earlier and had the rear diff fluid changed already to be safe as the truck is in water on a regular basis and syn. lube water is its biggest enemy I'm told....plus its below freezing here for the next 4-5 months so for me its more of a contamination issue and preventive maintenance
2001 SD 4x4 5.4 auto 3:73
Old 12-02-2001, 05:31 PM
Try Napa, I believe I saw it there.
Les
Old 12-02-2001, 07:00 PM
1STFORD 1STFORD is offline
1STFORD is starting off with a positive reputation.
fjlee,
Summit Racing carries, Richmond Gear GL-6 75W-140 Synthetic Gear Oil. Call 1-800-230-3030 and order RMG-LUBE, $9.95 quart.
I used this in my previous 1992 Chevy C1500's Lock-Rite positraction unit for 9 years(78,000 miles) and my 1996 HD Road King motorcycle transmission for 4 years(35,000 miles). Goooooood stuff... I now own a 2001 F250 SDSC 4X2 with 5.4 and 3:73 LSD
Respectfully,
David:
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
140, 2001, 75w140, boys, change, differential, f250, ford, gear, lockrite, lube, oil, pep, richmond, synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
