1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Axle Codes
Old 11-24-2001, 11:19 PM
Todd C's Avatar
Todd C
Todd C is offline
Axle Codes
Does anyone know where I can find a list of axle codes. I have a '99 F250 SD SC and I'm trying to find out which housing/gear ratio is in this truck so I know which fluid to use when changing. Owners manual tells of several different housings using several different fluids, but doesn't tell me what the C2 axle code on the door pillar means. My old '92 manual told me all about the codes, this one tells me squat!!
Thanx!!
Todd C.
Old 12-02-2001, 05:07 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Axle Codes
your post is kinda old, so i hope you get this.
Crawl under your truck and look at the tags on the axles. they'll tell you the ratios. Not sure what you meant by housing but you should have a Dana 50 front and Ford 10.5 in the rear. That's about all I know...hope it helps
Old 12-02-2001, 05:46 PM
BlueDog's Avatar
BlueDog
BlueDog is offline
Axle Codes
CTC01
08-11-2013 11:39 AM
todd jo
02-18-2011 02:12 AM
todd jo
04-14-2007 10:30 AM
Renegadex
03-27-2006 11:42 PM
bcguys
07-19-2002 08:09 PM
Quick Reply: Axle Codes
