Ford 300 vs. Dodge 360 - Ford Truck Enthusiasts Forums
Old 02-26-2004, 07:27 PM
bulldog150 bulldog150 is offline
bulldog150 is starting off with a positive reputation.
alright i have this moron friend who has 96 Ram with a 360. All he ever does is bad mouth fords. HE always brags how he has thisi big *** 5.9L 360ci dodge engine. He tells me how im stupid for getting the legendary 300, he tells me 6 cylinder engines do not belong in trucks. He tells me how his dodge will last forever and how my ford with 143k is gonna give me nothin but problems. He has only 83k miles on his truck and he has problems all the time. In your opinion what do u think is a better engine? Which is better for towing, hauling, and durability. Plus give me somethin to say to him that will put his dodge down and realize that dodges SUCK!
Old 02-26-2004, 07:30 PM
Rawhide Rawhide is offline
Rawhide is starting off with a positive reputation.
dodges SUCK!
Old 02-26-2004, 09:11 PM
jessfactor jessfactor is offline
jessfactor is starting off with a positive reputation.
well his engine has way more power that yours, but its a big V8. he probably gets like 10 mpg's. i think the 5.9 is a nice engine, but its impractical for daily driving. the straight six gets great fuel efficiency, but will haul when you want it too.
does your friend realize that the cummins diesel in the dodge ram's is a 5.9 straight six? also, almost every tractor trailer is a straight six. the inline six is a real truck engine, not a V8. do you think a V8 will haul 80,000 lbs haha. say "what are those two extra cylinders in your truck for? i'll bet you can out pull all those 18 wheelers w/the straight six's (say it sarcasticly)"
print these pages out for him.
http://refrigeratedtrans.com/ar/tran...ides/index.htm
http://www.etrucker.com/apps/news/article.asp?id=23768
Old 02-26-2004, 09:14 PM
MontanaFord MontanaFord is offline
MontanaFord is starting off with a positive reputation.
stick w/ your 300-6...it'll give you double the miles you have currently, with the proper care and maintainence, and a few rebuilds if you want...it'll have all the pulling power you'll ever want, even if you don't have the horsepower of a v-8...the 300 has been around for 40+ years...there must be a reason for it...obviously it is a good motor, or it would not have lasted that long...granted, the dodge 360 is a good motor...my uncle loves his, and it's a 70-some with, i believe 200,000+ miles...but it has been well maintained and taken care of...all the 360 is, tho, is a bored-out 318...just some thoughts of mine...i love the 300...it's an awesome motor that will generally give you more in longevity than you could ever dream....
MontanaFord
Old 03-16-2004, 05:45 PM
pimpdaddyFry pimpdaddyFry is offline
pimpdaddyFry is starting off with a positive reputation.
Dodge sucks and needs to die! They should start making go-karts or something, and putting their engines in them.
Old 03-16-2004, 05:58 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
I see a bunch of kids here... Brand loyalty is for the birds...
As for our origional poster, I'll bet if your friend had the 300 powered Ford and you had the Dodge, he'd be bragging about the 300... Some people are like that, just ignore it, it's not worth getting worked up over.
Properly maintained, both engines will probably last just as long.
Old 03-16-2004, 07:04 PM
desperado_18_2000's Avatar
desperado_18_2000 desperado_18_2000 is offline
desperado_18_2000 is gaining momentum as a positive member of FTE.
I wouldn't worry about what he says, we all know the 300 is a great engine, and the dodge 360, is ok. I've worked on plenty of both of them.
Best way to shut him up is ignore it, because it really isn't worth getting bothered over.
Keep the oil changed, tuned up, and maybe a few speed parts added, and don't worry about his bucket mouth....just smile & wave as you pass.
Old 03-16-2004, 07:28 PM
rhetor rhetor is offline
rhetor is starting off with a positive reputation.
I'm sure the 360 is a stronger motor.
The 300 is great, i love mine to death, but that doesn't make it invincable. Its great for 300ci. Now if the 360 is great for 360ci, well its got that 60 cubes on the 300.
What the 300 lacks in power (and this only due to its size when compared to the other, bigger v8 truck motors) it makes up for in longevity and loyalty. What a great motor.
I'm gunna feel bad if i end up swapping in the 460... but probably only for a little while
The 300 should be in a ranger.
Old 03-16-2004, 10:27 PM
There Goes The Neighborhood's Avatar
There Goes The Neighborhood There Goes The Neighborhood is offline
There Goes The Neighborhood is starting off with a positive reputation.
Big 6 is better. Dodge 360 is a good motor, but the 6 is way more reliable. My dad's has over 200,000, and I know a guy with over 350,000 miles, w/o a rebuild.
Old 03-16-2004, 11:38 PM
RiveraD123 RiveraD123 is offline
RiveraD123 is starting off with a positive reputation.
the 360 is not just a bored out 318, the 318 has a stroke of 3.31, the 360 is 3.58, the bore on a 318 is 3.94, and the 360's bore is 4.00, its alot different, I love dodge, and I like ford just as much, I just cant get enough my my f-150 4x4 5 spd. the 360 in my 1970challenger has 485 horspower, and I love pulling it to the track with my ford!
Old 03-17-2004, 12:00 AM
dogdaysunrise dogdaysunrise is offline
dogdaysunrise is starting off with a positive reputation.
Just tell him that your 6 cyl is a big block, and his 360 is a small block. it doesnt mean much, but if its bragging your looking for then use it. thats about all the bragging rights its got.
Old 03-17-2004, 09:48 AM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
Re: Ford 300 vs. Dodge 360
Quote:
the post 1992 360 magnum is a pathetic, weak, gas guzzling, cylinder head cracking boat anchor.
his 96 dodge is a overly front heavy truck with a weak motor and a bad transmission and small brakes.
Dodge stopped making real trucks in 92-93 (some 1-tons kept the old frame and body style into the 93 model year)
Old 03-17-2004, 01:49 PM
Oscar Meier Oscar Meier is offline
Oscar Meier is starting off with a positive reputation.
I really don't know anything about Dodge; but, it seems that my neighbor's big Dodge truck is always parked in the garage or driveway broke down.
I drive by almost everyday in my '86 150 with a 300 IL & 170 K miles.
I am not sure who has the best truck; but, I am glad my neighbor's wife has a good car for him to drive to the parts store.
Old 03-17-2004, 06:49 PM
coupedeville coupedeville is offline
coupedeville is starting off with a positive reputation.
.Find yourself a new friend who isn't a moron. Or, just ignore the one you've got.
It's all so junior high school-ish.
Old 03-21-2004, 12:34 AM
StormChaos's Avatar
StormChaos StormChaos is offline
StormChaos is starting off with a positive reputation.
Stick with your 300. I used to work on dodges all day every day. Next time your friend blows a gasket, rmind him you still have your factory originals. And to say that the ram is front heavy, well so is the 4.9 F150. the 4.9 is fords heavyest block. thats because every thing is cast. (very good thing) And for bragging rights. I have raced many of rams, still have to lose to one yet. I'm still running stock. well except for a K&N air filter and ripped off my muffler.
Move over toyota boy, real men drive Fords!!!!
94 F150 4.9 inline six.
Triton v10 vs Dodge v10!!! lcpln8 Modular V10 (6.8l) 22 02-28-2008 01:03 PM
Dodge Ram 1500 w/Hemi Buck 1 2004 - 2008 F150 12 05-23-2007 12:05 PM
04 F150 vs 04 Dodge Ram Emghemi Ford vs The Competition 32 01-28-2005 06:10 AM
ford 1/2 ton 4x4 vs dodge 3/4 ton 4x4 Gerry Lutz Jr. Ford Inline Six, 200, 250, 4.9L / 300 17 12-22-2004 02:49 PM
Not to brag but............. Dustin_86 Offroad & 4x4 39 02-06-2004 10:54 PM
Tags
1986, 250, 360, 49, 59, dodge, engine, f250, ford, i6, motorhome, powerful, pull, quality, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
