AOD with low fluid pressures
On my F150 with the AOD the tranny seems to have some low fluid pressures. I hooked in a guage and got these pressures from it.
N - 45 psi
OD, D, 1 - 45 psi
R - 75 psi
Now from what I have gathered the reverse pressure is on the bottom side of normal but the others are about 10 psi too low. I have readjusted the TV cable and still no change. The tranny will sometimes shift just fine but at others will downshift horrible. It will sort of bog down everything and then if you hit the gas right after it slams into gear, so to speak. It will also downshift hard or shift to early as well. When it shifts too early it seems like there is a lot less power when accelerating no matter what the rpm range. Any thoughts on this one? Any help is greatly appreciated.
N - 45 psi
OD, D, 1 - 45 psi
R - 75 psi
blitzkraig56
03-25-2007 04:05 PM
richardvestal
03-07-2005 02:27 PM
Lightning4me
07-20-2004 04:23 PM
blifsey
03-21-2002 09:48 PM
