Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-26-2004, 12:50 PM
ferguson777's Avatar
ferguson777 is starting off with a positive reputation.
Mild ignition upgrade - suggestions?
Application - 1990 F150 302 engine with SD-EFI in a 54 F100.
With the mild upgrades being done to this engine (i.e. headers, mild cam, port & polish) It's been stated (and I believe it) that an full blown MSD6 ignition system would be overkill/excessive.
So, going with the stock ignition, other than a complete rebuild, it there anything I can/should do to improve the spark?
i.e. better coils?
Thanks,
__________________
RMF
Q: What year is that truck?
A: Which part?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-26-2004, 03:23 PM
jwtaylor is starting off with a positive reputation.
I would say your stock ignition is fine, you won't see any real gains, IMO, given it efi.
Wouldn't change the coil either, all the coil does is provide the spark, an aftermarket would give you a little more energy, but the stock one isn't that bad.
You might consider a msd or another ignition box, as it actually controls the spark duration and frequency. IMO, I would put that money towards something else. Good luck
  #3 (permalink)
Old 02-26-2004, 10:00 PM
nastruk95 is starting off with a positive reputation.
I saw no improvrement with msd 6a only the blaster2 coil made the difference and the 50ohm/foot ignition wires. If I jad the decision to do it again I'd go with out the ignition box
  #4 (permalink)
Old 02-27-2004, 08:14 AM
O.K., Thanks guys.
__________________
RMF
A: Which part?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
